Track changes in Nagios XI?
brandondash
Post by brandondash »
Over the weekend one of our dashlets was changed. I have a few questions:
  • When a dashlet is changed by a user with admin privileges, does that trigger an audit log entry?
  • If so, what entry type is it? I assume Change or Modify
  • Side note, what's the difference between Change and Modify?
  • If there is no audit entry, why not?
  • Is there any mechanism that lets you know what gets changed when it happens?
Thanks in advance!
bolson
Re: Track changes in Nagios XI?
Post by bolson »
Hello BRANDONDASH,
Are you talking about a dashlet or a dashboard being changed?
brandondash
A dashlet was replace with another dashlet inside a dashboard.
bolson
Post by bolson »
Unfortunately, these type of changes are not logged by Nagios. Do you have any additional questions or may we close this topic?
brandondash
What is the difference between "Change" and "Modify" in the audit logs?
bolson
Post by bolson »
I'll need to do some research and get back to you on that.
