check_jmx error: JMX CRITICAL com.sun.enterprise.admin.util.
rohithroki
Post by rohithroki »
Dear Team,
I am trying to configure nagios monitroring for one of my java application and when i try to run the check_jmx plugin from the nagios server i am getting the below error.
Kindly let me know if i am missing anything here.Please find the command which i am executing from the nagios server.
I have copied the check_jmx and jmxquery.jar in the path /usr/local/nagios/libexec
./check_jmx -U service:jmx:rmi:///jndi/rmi://x.x.x.x:8686/jmxrmi -O com.itac.management:type=Servers,host=*,process=* -A UsedHeapSize -w 18000000000 -c 20000000000 -p B -username xxxx-password xxxx
regards,
RKJ
Re: check_jmx error: JMX CRITICAL com.sun.enterprise.admin.u
Post by mcapra »
Can you show us the specific error your are getting? A copy+paste of the command executed and it's corresponding output would be useful.
Can you also describe how JMX is configured in the remote application you are trying to monitor?
Post by dwhitfield »
Thanks @mcapra!
rohithroki wrote:i am getting the below error.
Looks like it didn't come through.
rohithroki
apologies please find the error screenshot below
JMX CRITICAL com.sun.enterprise.admin.util.AdminLoginModule$PrincipalCallback
I have executed the below command
Also when i am executing below command getting the below error
./check_jmx -U service:jmx:rmi:///jndi/rmi://x.x.x.x:8686/jmxrmi -O java.lang:type=Memory -A HeapMemoryUsage -K used -I HeapMemoryUsage -J used -vvvv -w 4248302272 -c 5498760192 -username xxx -password xxxx
JMX CRITICAL Error unmarshaling return; nested exception is:
java.io.WriteAbortedException: writing aborted; java.io.NotSerializableException: com.sun.enterprise.admin.util.AdminLoginModule$PrincipalCallback connecting to java.lang:type=Memory by URL service:jmx:rmi:///jndi/rmi://10.179.83.80:8686/jmxrmijava.rmi.UnmarshalException: Error unmarshaling return; nested exception is:
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:245)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:160)
at javax.management.remote.rmi.RMIServerImpl_Stub.newClient(Unknown Source)
at javax.management.remote.rmi.RMIConnector.getConnection(RMIConnector.java:2366)
at javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:310)
at javax.management.remote.JMXConnectorFactory.connect(JMXConnectorFactory.java:268)
at javax.management.remote.JMXConnectorFactory.connect(JMXConnectorFactory.java:227)
at org.nagios.JMXQuery.connect(JMXQuery.java:53)
at org.nagios.JMXQuery.main(JMXQuery.java:75)
Caused by: java.io.WriteAbortedException: writing aborted; java.io.NotSerializableException: com.sun.enterprise.admin.util.AdminLoginModule$PrincipalCallback
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1357)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:2016)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1940)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1806)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1353)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:373)
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:243)
... 8 more
Caused by: java.io.NotSerializableException: com.sun.enterprise.admin.util.AdminLoginModule$PrincipalCallback
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1184)
at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1548)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1509)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1432)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
at java.io.ObjectOutputStream.defaultWriteObject(ObjectOutputStream.java:441)
at java.lang.Throwable.writeObject(Throwable.java:985)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:1028)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1496)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:384)
at sun.rmi.transport.Transport$1.run(Transport.java:200)
at sun.rmi.transport.Transport$1.run(Transport.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:196)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:568)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:826)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:683)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:682)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Post by mcapra »
mcapra wrote: Can you also describe how JMX is configured in the remote application you are trying to monitor?
Please address the above.
This article might be useful:
https://blogs.oracle.com/quinn/jmx-moni ... sh-servers
rohithroki wrote:apologies please find the error screenshot below
Did you mean to attach a screenshot or is that just a typo regarding the error?
Also, please see @mcapra's question above.
rohithroki
@dwhitefield yes it was a a typo. i have pasted the error logs in the previous reply.
@mcapara i will check with application team on the same and update you the status.
Regards,
RKJ
Post by mcapra »
It's worth mentioning that if you're using the Glassfish JMX server rather than Java's native RMI, you may need to do some tinkering within the jmxquery.jar package. I don't have a Glassfish server to test against unfortunately; Perhaps I'll add one to my lab environment.
Can you also share where you got check_jmx from? There's many different iterations of that plugin from different maintainers.
Thanks for the assist, @mcapra! OP, let us know if you need further assistance.
