Apply Config throws error but says no error
Have a weird one. I made some changes to Nagios and tried to apply the config. It failed and says there was an error. I click on the "Show Error" button and I just get a highlighted line with no text. I have attached a screenshot, an audit log of the last 24 hours, and the system profile.
Please take a look and see if you can see the issue.
Thanks.
Thanks.
Re: Apply Config throws error but says no error
Please run the following command from the command line and post your result:
OK, please find it attached.bolson wrote:Please run the following command from the command line and post your result:
I saw the warnings about the partition checks on the Nagios server. I corrected those and tried to apply but had the same result.
Thanks.
bolson wrote:Can you run this again and post the result?Code: Select all
Ummm... OK. Here you go.
I think these configuration warnings could be the culprit. Please attach your /usr/local/nagios/etc/nagios.cfg.
Thank you!
Thank you!
Here you go. Thank you for looking.
It may also be helpful to see the output of the following command executed from the CLI of your Nagios XI machine:
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
OK. I had to take 2 screen shots to get it all. Capture1.PNG is the last of the output.mcapra wrote:It may also be helpful to see the output of the following command executed from the CLI of your Nagios XI machine:Code: Select all
Do you see any config errors when go to the CCM > Tools > Config File Management, and click on the following buttons in the exact same order: Delete Files, Write Configs, and Verify Files?
If you don't see any errors, try to apply configuration. If this still fails, run the following commands, and show the output:
Also, start a running tail on the cmdsubsys.log, and redirect the output to a text file:
While the tail is running, apply configuration in the web UI. When this is done (you see an error in the web UI), go back to the terminal, and stop the tail by pressing "Ctrl + c". Next, post the "debug.txt" file that was generated in the "/tmp" directory.
chage -l nagios
chage -l apache
sestatus
ls -la /usr/local/nagiosxi/scripts/nagiosql*
tail -f /usr/local/nagiosxi/var/cmdsubsys.log &> /tmp/debug.txt
