Settings on the Backup and Maintenance are not staying
When I am making changes to the settings on the Backup/Maintenance interface on Nagios Logging server 1.4.4 When I click Save it does not stay persistent. It goes back to the default settings. In addition bloom filter cache is missing from the user interface as well.
Any help would be great.
Re: Settings on the Backup and Maintenance are not staying
Sounds like a possible issue with the nagioslogserver index. Please run the following and post the output:
I'd also like you run:
Where the CLUSTER_ID can be found by looking at the second line of output from the previous command. Let this run while you try to write and save the changes again in the web UI. Provide anything that may be generated on the cli when you do.
curl -XGET 'http://localhost:9200/_cluster/health/*?level=shards&pretty'
tail -f /var/log/elasticsearch/<CLUSTER_ID>.log
curl -XGET 'http://localhost:9200/_cluster/health/* ... rds&pretty'
"cluster_name" : "redacted----",
"status" : "yellow",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 25,
"active_shards" : 25,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 25,
"number_of_pending_tasks" : 0,
"number_of_in_flight_fetch" : 0,
"indices" : {
"nagioslogserver_log" : {
"number_of_shards" : 5,
"number_of_replicas" : 1,
"active_primary_shards" : 5,
"active_shards" : 5,
"unassigned_shards" : 5,
"shards" : {
"0" : {
"primary_active" : true,
"active_shards" : 1,
"unassigned_shards" : 1
"1" : {
"2" : {
"3" : {
"4" : {
"nagioslogserver" : {
"shards" : {
"0" : {
"1" : {
"2" : {
"3" : {
"4" : {
"kibana-int" : {
"shards" : {
"0" : {
"1" : {
"2" : {
"3" : {
"4" : {
"logstash-2017.08.08" : {
"shards" : {
"0" : {
"1" : {
"2" : {
"3" : {
"4" : {
"logstash-2017.08.09" : {
"shards" : {
"0" : {
"1" : {
"2" : {
"3" : {
"4" : {
Last edited by kseasolutions on Thu Aug 10, 2017 12:35 pm, edited 1 time in total.
From the tail I can see the error fairly clear
[2017-08-09 15:45:18,741][DEBUG][action.index ] [--redact--] [nagioslogserver][1], node[--redact--], [P], s[STARTED]: [color=#FF0000]Failed to execute [index {[nagioslogserver][cf_option][maintenance_settings], source[{"created":"2017-01-03 22:55:13","created_by":0,"value":"a:6:{s:13:\"optimize_time\";s:1:\"5\";s:10:\"close_time\";s:1:\"7\";s:11:\"delete_time\";s:2:\"30\";s:10:\"repository\";s:15:\"Archive_indexes\";s:20:\"delete_snapshot_time\";s:2:\"90\";s:6:\"active\";s:1:\"1\";}","modified_by":"AVz2hp3mHpAy0Akc-9b_"}]}][/color]
org.elasticsearch.index.mapper.MapperParsingException: failed to parse [modified_by]
at org.elasticsearch.index.mapper.core.AbstractFieldMapper.parse(AbstractFieldMapper.java:411)
at org.elasticsearch.index.mapper.object.ObjectMapper.serializeValue(ObjectMapper.java:706)
at org.elasticsearch.index.mapper.object.ObjectMapper.parse(ObjectMapper.java:497)
at org.elasticsearch.index.mapper.DocumentMapper.parse(DocumentMapper.java:544)
at org.elasticsearch.index.mapper.DocumentMapper.parse(DocumentMapper.java:493)
at org.elasticsearch.index.shard.IndexShard.prepareIndex(IndexShard.java:493)
at org.elasticsearch.action.index.TransportIndexAction.shardOperationOnPrimary(TransportIndexAction.java:192)
at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$PrimaryPhase.performOnPrimary(TransportShardReplicationOperationAction.java:574)
at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$PrimaryPhase.routeRequestOrPerformLocally(TransportShardReplicationOperationAction.java:444)
at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$PrimaryPhase.doRun(TransportShardReplicationOperationAction.java:370)
at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:36)
at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction.doExecute(TransportShardReplicationOperationAction.java:112)
at org.elasticsearch.action.index.TransportIndexAction.innerExecute(TransportIndexAction.java:136)
at org.elasticsearch.action.index.TransportIndexAction.doExecute(TransportIndexAction.java:114)
at org.elasticsearch.action.index.TransportIndexAction.doExecute(TransportIndexAction.java:63)
at org.elasticsearch.action.support.TransportAction.execute(TransportAction.java:75)
at org.elasticsearch.action.update.TransportUpdateAction.shardOperation(TransportUpdateAction.java:217)
at org.elasticsearch.action.update.TransportUpdateAction.shardOperation(TransportUpdateAction.java:170)
at org.elasticsearch.action.support.single.instance.TransportInstanceSingleOperationAction$AsyncSingleAction$1.run(TransportInstanceSingleOperationAction.java:187)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NumberFormatException: For input string: "AVz2hp3mHpAy0Akc-9b_"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Long.parseLong(Long.java:441)
at java.lang.Long.parseLong(Long.java:483)
at org.elasticsearch.common.xcontent.support.AbstractXContentParser.longValue(AbstractXContentParser.java:145)
at org.elasticsearch.index.mapper.core.LongFieldMapper.innerParseCreateField(LongFieldMapper.java:288)
at org.elasticsearch.index.mapper.core.NumberFieldMapper.parseCreateField(NumberFieldMapper.java:239)
at org.elasticsearch.index.mapper.core.AbstractFieldMapper.parse(AbstractFieldMapper.java:401)
... 21 more
Last edited by kseasolutions on Thu Aug 10, 2017 12:37 pm, edited 1 time in total.
I'm betting modified_by and created_by are both typed as longs rather than strings. I believe this is a known issue within NLS, though I don't have a reference number for the bug.
Can you share the full output of the following command executed from the CLI of one of your Nagios Log Server machines:
Please wrap it in
curl -XGET 'http://localhost:9200/nagioslogserver/_mapping/'
tags as the output will be quite long.
Also, which account are you making these changes from? I'm betting the default nagiosadmin account is able to make the changes without issue.
{"nagioslogserver":{"mappings":{"user":{"properties":{"apiaccess":{"type":"string"},"apikey":{"type":"string"},"auth_settings":{"properties":{"ad_username":{"type":"string"},"auth_server_id":{"type":"string"},"dn":{"type":"string"},"type":{"type":"string"}}},"auth_type":{"type":"string"},"created":{"type":"string"},"created_by":{"type":"long"},"default_dashboard":{"type":"string"},"email":{"type":"string"},"lang":{"type":"string"},"language":{"type":"string"},"name":{"type":"string"},"password":{"type":"string"},"username":{"type":"string"}}},"node":{"properties":{"address":{"type":"string"},"config_filters":{"properties":{"active":{"type":"long"},"name":{"type":"string"},"raw":{"type":"string"}}},"config_inputs":{"properties":{"active":{"type":"long"},"name":{"type":"string"},"raw":{"type":"string"}}},"elasticsearch":{"properties":{"message":{"type":"string"},"pid":{"type":"string"},"status":{"type":"string"}}},"hostname":{"type":"string"},"last_updated":{"type":"long"},"logstash":{"properties":{"message":{"type":"string"},"pid":{"type":"string"},"status":{"type":"string"}}},"ls_release":{"type":"long"},"ls_version":{"type":"string"}}},"snapshot":{"properties":{"auto":{"type":"long"},"clean_filename":{"type":"string"},"created":{"type":"long"},"filename":{"type":"string"},"name":{"type":"string"},"path":{"type":"string"}}},"cf_option":{"properties":{"created":{"type":"string"},"created_by":{"type":"long"},"modified_by":{"type":"long"},"value":{"type":"string"}}},"commands":{"properties":{"active":{"type":"long"},"args":{"properties":{"path":{"type":"string"},"sh_created":{"type":"long"},"sh_id":{"type":"string"},"timezone":{"type":"string"}}},"command":{"type":"string"},"created":{"type":"string"},"created_by":{"type":"string"},"frequency":{"type":"string"},"last_run_output":{"type":"string"},"last_run_status":{"type":"string"},"last_run_time":{"type":"string"},"node":{"type":"string"},"run_time":{"type":"long"},"status":{"type":"string"},"type":{"type":"string"}}},"query":{"properties":{"created_by":{"type":"string"},"created_id":{"type":"string"},"edit_type":{"type":"string"},"imported":{"type":"long"},"name":{"type":"string"},"raw":{"type":"string"},"services":{"type":"string"},"show_everyone":{"type":"long"},"title":{"type":"string"}}}}}}
Yup:
Have you tried making the changes by using the nagiosadmin user? I'll defer to a tech in terms of a fix, since I don't recall specifically what the "official" fix was.
"cf_option": {
"properties": {
"created": {
"type": "string"
"created_by": {
"type": "long"
"modified_by": {
"type": "long"
"value": {
"type": "string"
I just made the changes as the official Nagiosadmin user and they stuck this time (though bloom is still not an option)
Previously, I was in an admin account, but not nagiosadmin.
Thank you for the post @mcapra. I will wait to see what the technical fix is on this.
Thank you once again.
The bloom filter has been removed in the current version as it is no longer used.
This is a remnant of a previous bug, to fix the mapping problem you will want to do the following
create a new system backup
The restore this backup
find the newest file file
use that to restore the backup
/usr/local/nagioslogserver/scripts/create_backup.sh
ls -l /store/backups/nagioslogserver/
/usr/local/nagioslogserver/scripts/restore_backup.sh /store/backups/nagioslogserver/nagioslogserver.2017-08-10.XXXXXXX.tar.gz
