I've recently used the import config files tool and everything imported correctly except the check-commands from all host-templates.
Does anyone know why this may be and how to resolve the issue?
I used the following documentation:
https://assets.nagios.com/downloads/nag ... p-Tool.pdf
Importing files from a Nagios Core version 3.2.3 to Nagios XI version 5.4.8
Thank-you!
Import config files- host templates error
- Former Nagios Staff
Re: Import config files- host templates error
Please attach one of your host templates that did not import correctly. Also, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
This issue was resolved, the thread may be closed.
