Custom reports
vinish098
Custom reports
Post by vinish098 »
1) By default, availability reports of a host in selected time frame is in "%" like UP(99.94%), Down(0.06%) & Unreachable(0.00%). We want these reports output to be in minutes like UP(120 minutes), Down(30 minutes) & Unreachable(10 minutes) like that.
2) We required performance graph of a individual service or host in user defined interval like 2hours, 3hours, 8hours, etc.
3) We want to pull the reports in a user defined time frame and we can select multiple hosts and multiple services randomly on single screen and able to download the reports in pdf format.
4) Suppose we are monitoring 100 linux servers. Our requirement is to pull the reports of top resources consumption of RAM, CPU etc in a user defined time frame and can be downloaded in pdf format.
Please help here. Thanks in advance!!
Re: Custom reports
Post by dwhitfield »
1. There reporting engine is being rebuilt in Nagios XI 6.0. Unfortunately, I do not have a release date as of the moment. Details at https://www.nagios.com/roadmaps/
2. You can drag on the graphs to select custom times. If you have additional questions about graphs I would suggest opening a different thread, as graphs and reports are not the same.
3. You are going to have to define randomly. Have you installed an XI trial and looked at the reports at all? It sounds like you looked at the Availability report, but most of the reports have a custom time frame, and you mention that, so I wonder if you installed a trial, or was just looking at documentation. You don't need much power to just install a poke around.
4. If you set up your groups correctly, you could do this with the Top Alert Producers.
vinish098
Re: Custom reports
Post by vinish098 »
Can you please let us know the database structure of Nagios. We are very much interested in creating some custom reports using JasperReports.
Pls help
Re: Custom reports
We do not have much in the way of public documentation on our database schema, as we generally discourage people from making modifications (which can cause damage to your system if not done properly). Your DBA should be able to get the schema with a few describe statements.
