URL monitoring in Nagios cor from command prompt
Hi Team,
I am new to Nagios core. And want to monitor urls I have created service like below on nagios server
host_name DMSAPS01
service_description URL: http://10.0.1.8:9500/dsearch
check_command check_http!http://10.0.1.8:9500/dsearch
When I run check_http I get below command. Please help me on it
[root@DMSAMON01 libexec]# ./check_http -H 10.0.0.8 -u http://10.0.0.8:9500/dsearch
connect to address 10.0.0.8 and port 80: Connection refused
HTTP CRITICAL - Unable to open TCP socket
Thanks.
host_name DMSAPS01
Thanks.
Re: URL monitoring in Nagios cor from command prompt
jyoti22 wrote:Hi Team,
host_name DMSAPS01
Thanks.
It should be more like this
./check_http -H 10.0.0.8 -u /dsearch -p 9500
[nagadmin@clouddms.com@DMSAZPLMON01 libexec]$ ./check_http -H 10.0.0.8 -u /dsearch -p 9500
HTTP WARNING: HTTP/1.1 404 Not Found - 246 bytes in 0.004 second response time |time=0.004413s;;;0.000000 size=246B;;;0
Please let me know what should be syntax of service.cfg file
Thanks.
Thanks.
Are you sure this URL exists and is accessible from the nagios XI server?
From the command line can you run
curl -vvv http://10.0.1.8:9500/dsearch
URL takes time to load, I guess due to this I get warning message. I tried to increase timeout to 500 (-t 500) but still I get same error.
Kindly help
Kindly help
A This errorjyoti22 wrote:URL takes time to load, I guess due to this I get warning message. I tried to increase timeout to 500 (-t 500) but still I get same error.
Kindly help
404 Not Found
Lets run the command with a -v and please post the output
./check_http -H 10.0.0.8 -u /dsearch -p 9500 -v
Please find the output.
[root@DMSAZPLMON01 libexec]# ./check_http -I 10.0.0.70 -u '/D2/#d2' -p 8080 -v
GET /D2/#d2 HTTP/1.0
User-Agent: check_http/v2.1.2 (nagios-plugins 2.1.2)
Connection: close
Accept: */*
http://10.0.0.70:8080/D2/#d2 is 1225 characters
STATUS: HTTP/1.1 404 Not Found
**** HEADER ****
Server: Apache-Coyote/1.1
X-UA-Compatible: chrome=1
Content-Type: text/html;charset=utf-8
Content-Language: en
Content-Length: 1006
Date: Wed, 06 Sep 2017 07:58:37 GMT
Connection: close
**** CONTENT ****
<!DOCTYPE html><html><head><title>Apache Tomcat/8.0.37 - Error report</title><st yle type="text/css">H1 {font-family:Tahoma,Arial,sans-serif;color:white;backgrou nd-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color: white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,san s-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family: Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Taho ma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma ,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black; }A.name {color : black;}.line {height: 1px; background-color: #525D76; border: n one;}</style> </head><body><h1>HTTP Status 404 - /D2/#d2</h1><div class="line">< /div><p><b>type</b> Status report</p><p><b>message</b> <u>/D2/#d2</u></p><p><b>d escription</b> <u>The requested resource is not available.</u></p><hr class="lin e"><h3>Apache Tomcat/8.0.37</h3></body></html>
HTTP WARNING: HTTP/1.1 404 Not Found - 1225 bytes in 0.006 second response time |time=0.006242s;;;0.000000 size=1225B;;;0
When I ran same url with IE, I get desired page. Please help. Thanks.
Connection: close
Accept: */*
**** HEADER ****
Connection: close
**** CONTENT ****
Well this is clearly a 404, which leads me to believe that the web server is only serving the page to certain hosts or IP's.jyoti22 wrote:Please find the output.
Connection: close
Accept: */*
**** HEADER ****
Connection: close
**** CONTENT ****
It shouldn't matter but in a URL items after and including # are never sent to a web server.
For clarity, this loads in your browser?
If so, you may need to speak to the person who setup the web server to determine if they have some type of filtering going on that they can add your Nagios server to as allowed.
It is working now. Please mark it as solved. Thanks a lot! ![Smile :)](./images/smilies/icon_e_smile.gif)
