Add more Host Groups Nagios
michaelpn
Post by michaelpn »
I would like to add more Host Groups on my Nagios Site. Right now I have one for Citrix Servers and would like to have one for Web Servers too. How it is possible to do that ? Right now as written I have crated a Config file for Citrix Servers "hostgroubs.cfg" then I would like to have one for my Web Servers. Why ? because then I have a better view on the Nagios interface.
michaelpn :)
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
tacolover101
Re: Add more Host Groups Nagios
Post by tacolover101 »
yes - just create a definition in any of your config files. (based on what config file or dirs you are picking up in your nagios.cfg)
https://assets.nagios.com/downloads/nag ... #hostgroup
Post by dwhitfield »
Thanks @tacolover101!
You can put all of the hostgroups in the same config file, or you can separate them out. Since you already have a hostgroups.cfg (I'm assuming that's correct), I would just go with that.
Are all of your web servers already set up as hosts? If not, you'll need to do that too.
DiegoAnjos
Post by DiegoAnjos »
Personally I prefer to have a file per host, so I define the hostgroup in each host file, as below:
	use			windows-server
	host_name	SRVXXX
	alias			SRVXXX
	address			192.X.X.X
	icon_image_alt		Intranet Server
	statusmap_image	www_server.gd2
	hostgroups		G03
	parents			SW-XXXXXX
On hostgroups.cfg I define the group:
define hostgroup{
        hostgroup_name  	G03
        alias           	        WEB SERVERS
TIP: I name my groups as G1, G2, G3, N1 and so on so Nagios Web Interface will sort them alphabetically.
The ALIAS I set with a friendly name to help myself and others to quickly find hosts/hostgroups.
Thanks @DiegoAnjos! That's exactly what we do in XI by default. I'd quibble with saying you define the hostgroup in the host file. You are setting or associating the hostgroup in the host file. The definition is in hostgroups.cfg per your example. I know what you mean, but I'm just clarifying for people new to nagios.
DiegoAnjos
@dwhitfield
Sorry, I am not a native english speaker. Thanks for making my statement more understandable :D
@DiegoAnjos, no problem!
FWIW, I think it's a fine English use of the word define, it's just that define has a very specific meaning in nagios config files. :)
OP, did you have any other questions?
michaelpn
Post by michaelpn »
many thanks for your answers. That is exactly what I have done. But if you look at my attachments you will see I only use "houstgroups.cfg" for my citrix- and web servers and nagiso shows that on the interface but what is nagging me is that Nagios shows me WSTEST1 on both host one for citrix-servers and web-servers. Why ?
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
Can you show the config for WSTEST1 and any templates that are applied?
michaelpn
Post by michaelpn »
please :)
windows.cfg
(7.27 KiB) Downloaded 641 times
templates.cfg
(10.35 KiB) Downloaded 480 times
hostgroups.cfg
(9.85 KiB) Downloaded 432 times
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
