Hi There,
I have try to monitoring a gpu on a windows machine. But I a bit confused about how can I get a value from a remote host. It's a passive check (snmp trap?) or active check (nsc?).
I read this link:
https://exchange.nagios.org/directory/P ... 1503417619
and this
https://www.thomas-krenn.com/en/wiki/GP ... ing_Plugin
Please advice the solution.
Thank you.
How can monitoring gpu on a windows?
Re: How can monitoring gpu on a windows?
The documentation you linked has it set up as an active check that is executed using the NRPE agent. You can reference the "Configuring the check_gpu_sensor Plugin" section for details regarding setting the check up in Nagios.dimsum wrote:It's a passive check (snmp trap?) or active check (nsc?).
There's a lot more work involved prior to actually configuring the check in Nagios, but that's mostly non-Nagios related environment configuration/setup on the Windows machine.
- Former Nagios Staff
What exactly are you trying to monitor? temperature, fan speed, load, something else? The exchange is definitely the place to start looking, but if you don't find what you need there, you might want to take a look at github.dimsum wrote: I have try to monitoring a gpu on a windows machine.
I focused on gpu temp, fan speed and load is't basically. I try connect with command then got a message
./check_gpu_sensor.pl -H 10.255.1.1
/usr/bin/perl: symbol lookup error: /usr/local/lib64/perl5/auto/nvidia/ml/bindings/bindings.so: undefined symbol: nvmlInit
How can I fix the error?
Thanks.
Thanks.
You may need to install the nvidia perl package http://search.cpan.org/~nvbinding/nvidi ... idia/ml.pm but ultimately, you'd likely to find more knowledgeable folks about that error on the nvidia forums...possibly perl forums. We can certainly continue to try to help, but we don't have access to every type of gpu here, so we may not be able to test.
Why GPU is this you are trying to monitor?
I have check a module is installed in perl. But when I run the check it's same error.
IO::CaptureOutput
List::Compare
Nagios::Monitoring::Plugin
Perl
nvidia::ml::bindings
My site is using gpu to compute a graphic work e.g. animation, video, 3d in cluster and they need to know about a temp, clock, load they are run on a windows group. For a routine job they are open on remote desktop and look a status from nvidia monitor or gpuz something like that.
Thank you.
IO::CaptureOutput
List::Compare
Perl
Thank you.
What command are you using for this? I was able to install a nvidia::ml, so I wonder if that's what you need rather than nvidia::ml::bindingsdimsum wrote: nvidia::ml::bindings
Any cpan output could also be useful.
