Config Files Permission Check errors
corkyman
Post by corkyman »
I have reconfigured Nagios to use an external MySQL instead of internal one and getting this error when clicking on Apply Config. Please look at the screen shot.
How can I determine the file with incorrect permissions?
kyang
Re: Config Files Permission Check errors
Post by kyang »
Hi @corkyman,
Could you run this through the command line and post your output?
OR
If you wanted to do this through the UI
From the XI home page go to Configure --> Core Config Manager --> On the bottom left under Tools tab --> Config File Management --> Verify Files
Did you follow any documentation when you were setting up an external MySQL database?
corkyman
Post by corkyman »
Yes, I followed instructions in one of the Nagios documents describing the process: https://assets.nagios.com/downloads/nag ... Server.pdf
[c601018@vhlgnngxi052 ~]$ sudo su - nagios
-bash-4.1$ /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_COMD' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_COMN' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_ECBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_FRAM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_IOBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_MFRM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_SH31' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_SH64' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES1_SWBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_COMD' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_COMN' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_ECBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_FRAM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_IOBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_MFRM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_SH31' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_SH64' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES2_SWBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_COMD' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_COMN' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_ECBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_FRAM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_IOBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_MFRM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_SH31' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_SH64' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES3_SWBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_COMD' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_COMN' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_ECBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_FRAM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_IOBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_MFRM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_SH31' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_SH64' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES4_SWBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_COMD' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_COMN' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_ECBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_FRAM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_IOBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_MFRM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_SH31' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_SH64' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES5_SWBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_COMD' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_COMN' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_ECBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_FRAM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_IOBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_MFRM' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_SH31' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_SH64' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_CoreBlocks_RES6_SWBS' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Efficiency_Level_RES1' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Efficiency_Level_RES2' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Efficiency_Level_RES3' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Efficiency_Level_RES4' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Efficiency_Level_RES5' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Efficiency_Level_RES6' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESB_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESC_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESD_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESE_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESF_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_CoreCount_RESG_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESB_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESC_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESD_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESE_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESF_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_4DP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_4LT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_4ST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_LDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_LLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_LST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_SDP' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_SLT' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_FilePools_FileCount_RESG_SST' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_InputList_Shutdown_Status_RES1' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_InputList_Shutdown_Status_RES2' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_InputList_Shutdown_Status_RES3' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_InputList_Shutdown_Status_RES4' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_InputList_Shutdown_Status_RES5' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_InputList_Shutdown_Status_RES6' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES1_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES1_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES1_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES2_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES2_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES2_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES3_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES3_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES3_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES4_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES4_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES4_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES5_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES5_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES5_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES6_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES6_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES6_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES_Total_CTL_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES_Total_OPR_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_RES_Total_SNP_Errors' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES1' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES2' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES3' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES4' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES5' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES6' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Real_CPU_RES_Average' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_System_Status_RES1' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_System_Status_RES2' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_System_Status_RES3' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_System_Status_RES4' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_System_Status_RES5' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_System_Status_RES6' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES1' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES2' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES3' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES4' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES5' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES6' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Deltamatic_Infrastructure_Weighted_CPU_RES_Average' on host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Service 'Total_Message_Rate' on host 'LCN5_Aggregates' has no default contacts or contactgroups defined!
Warning: Service '/ Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/boot Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/1 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/10 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/11 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/12 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/13 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/14 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/15 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/16 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/17 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/18 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/19 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/2 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/20 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/21 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/22 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/23 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/24 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/3 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/4 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/5 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/6 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/7 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/8 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/data/9 Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/dev/shm Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/home Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/logs Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/opt Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/projects Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/run Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/sys/fs/cgroup Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/tmp Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/var Disk Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service 'Swap Usage' on host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Service '/ Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/boot Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/1 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/10 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/11 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/12 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/13 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/14 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/15 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/16 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/17 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/18 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/19 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/2 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/20 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/21 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/22 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/23 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/24 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/3 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/4 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/5 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/6 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/7 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/8 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/data/9 Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/dev/shm Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/home Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/logs Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/opt Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/projects Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/run Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/sys/fs/cgroup Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/tmp Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service '/var Disk Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service 'Swap Usage' on host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive C: Disk Usage' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive D: Disk Usage' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Drive F: Disk Usage' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Physical Memory Usage' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Virtual Memory Usage' on host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Service 'Total Message Rate' on host 'hpplc501' has no default contacts or contactgroups defined!
Warning: Service 'Total Message Rate' on host 'hpplc503' has no default contacts or contactgroups defined!
Warning: Service '/ Disk Usage' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/mnt/nagios/shared Disk Usage' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/opt Disk Usage' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/store Disk Usage' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_COLO_Devices' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_CORP_Devices' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_FE_Devices' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_MGT_Devices' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'HTTP' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'I/O Wait' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Load' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Nagios XI Jobs' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Swap Usage' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'mysqld' on host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/ Disk Usage' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/mnt/nagios/shared Disk Usage' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/opt Disk Usage' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service '/store Disk Usage' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'CPU Usage' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_COLO_Devices' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_CORP_Devices' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_FE_Devices' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Gearman_Queue_MGT_Devices' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'HTTP' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'I/O Wait' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Load' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Nagios XI Jobs' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'Swap Usage' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Service 'mysqld' on host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Checked 715 services.
Warning: Host 'Deltamatic_Infrastructure' has no default contacts or contactgroups defined!
Warning: Host 'LCN5_Aggregates' has no default contacts or contactgroups defined!
Warning: Host 'OSS_Infrastructure' has no default contacts or contactgroups defined!
Warning: Host 'SHLPPFSKA001' has no default contacts or contactgroups defined!
Warning: Host 'SHLPPFSKA002' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPPFWS1010V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPPFWS1020V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPPPWS0010V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPPPWS0020V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPPPWS1010V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPPPWS1020V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPQAWS0010V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPQAWS0020V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPQAWS1010V' has no default contacts or contactgroups defined!
Warning: Host 'SPPSHPQAWS1020V' has no default contacts or contactgroups defined!
Warning: Host 'SVCNHPPPCS0010V' has no default contacts or contactgroups defined!
Warning: Host 'SVCNHPPPCS0020V.TVLPORT.NET' has no default contacts or contactgroups defined!
Warning: Host 'SVCNHPPPCS1010V' has no default contacts or contactgroups defined!
Warning: Host 'SVCNHPPPCS1020V' has no default contacts or contactgroups defined!
Warning: Host 'TEST' has no default contacts or contactgroups defined!
Warning: Host 'hpplc501' has no default contacts or contactgroups defined!
Warning: Host 'hpplc503' has no default contacts or contactgroups defined!
Warning: Host 'vhlgnngrg051.tvlport.net' has no default contacts or contactgroups defined!
Warning: Host 'vhlgnngxi001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Host 'vhlgnngxi002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Host 'vhlppngmn001.tvlport.net' has no default contacts or contactgroups defined!
Warning: Host 'vhlppngmn002.tvlport.net' has no default contacts or contactgroups defined!
Warning: Host 'vhlppngmn101.tvlport.net' has no default contacts or contactgroups defined!
Warning: Host 'vhlppngmn102.tvlport.net' has no default contacts or contactgroups defined!
Checked 94 hosts.
Checked 16 host groups.
Checked 0 service groups.
Checked 111 contacts.
Checked 4 contact groups.
Checked 138 commands.
Checked 116 time periods.
Checked 0 host escalations.
Checked 94 hosts
Checked 0 host dependencies
Checked 116 timeperiods
Checking misc settings...
Total Warnings: 425
Total Errors: 0
-bash-4.1$
Try running this script on the Nagios server to reset the permissions of the configurations file and hopefully it will fix that error.
Run the following as root
./reset_config_perms.sh
Try that and let us know if that fixed the issue.
corkyman
Post by corkyman »
This fixed it, thank you. Please close the incident.
kyang
Post by kyang »
Glad to hear it's fixed.
Closing this topic as resolved, if you have any more questions feel free to open another forum topic.
Thank you for using the Nagios Support Forums!
