Hi there,
I just did my first time try on Nagios XI. I am able to add multiple hosts and explore/edit most options. However, the most important feature Notifications doesn't work in my installation.
What I have now:
1. in Admin-->Manage Email Settings, I can receive test emails.
2. In Configure Host--> Notifications, I set send a notification immediately and send to myself.
3. In My account --> Notification Preferences, I set Enable notifications and checked both email and sms notification. and checked most of alerts. I can receive test notifications.
4. In System Settings--> Send Notification, it was set checked by default. I didn't touch it.
So which part I missed? It's a brand-new installation. How do I know the system tried to send notice or not. I do see multiple Host offline in Latest alerts. but I never receive a single notifications.
It seems to me complicated on this part when it doesn't work.
Thanks in advance.
Not receive email alert on Nagios XI
Re: Not receive email alert on Nagios XI
Hi @z.yong,
Have you looked at our documentation on configuring email and SMS?
Also you could take a look at our kb article on notification problems.
https://support.nagios.com/kb/article.php?id=36
Take a look at these, and let me know how it goes.
Thanks for the reply. sorry for the delay. I did check the article and I cannot find the cause. Please share more hints if any.kyang wrote:Hi @z.yong,
I checked phpmailer.log. there is only log for my test email. nothing else.
Here is the log in notifications.
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Nagios XI Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: xi_service_event_handler Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: xi_host_event_handler Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: process-service-perfdata-pnp-normal Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: process-service-perfdata-file-pnp-bulk Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: process-service-perfdata-file-bulk Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: process-host-perfdata-pnp-normal Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: process-host-perfdata-file-pnp-bulk Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: process-host-perfdata-file-bulk Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: notify-service-by-email Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: notify-host-by-email Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: check_none Name or service not known
2017-09-25 22:07:14 192.168.33.251 HTTP No CRITICAL nagiosadmin Custom: check-host-alive-tftp Name or service not known
what else should I check?
- Support Tech
@z.yong Hi Z.Yong, Did you enable "Recieve alerts via email" in In My account --> Notification Methods? Also, can you make sure that your contact has the right email in Configure > Core Config Manager > Alerting > Contacts?
You should also check your which contact template you are using.
Located in the Configure --> Core Config Manager --> under alerting tab --> Contacts --> Common Settings --> Manage Contact Templates --> tell us which template, either (xi_contact_generic OR generic-contact)
In that same location go to --> Alerting settings --> Manage Host Notification Commands and Manage Service Notification Commands--> tell us which one you have in there if any.
