how to disable active passive checks and notifications
benhank
Post by benhank »
Hey guys!
Is it possible to disable passive and active checks and notifications from the command line?
I backup my pri server and restore it to the secondary, and I want to add line(s) to it that will disable the above for me so the restored server wont fire up running checks and sending notifications.
Thanks!
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: how to disable active passive checks and notifications
You can simply modify the main config file (nagios.cfg), and set:
# To disable active host/service checks
execute_host_checks=0
execute_service_checks=0
# To stop accepting host/service passive checks
accept_passive_host_checks=0
accept_passive_service_checks=0
# To disable notifications globally
enable_notifications=0
Then restart nagios.
service nagios restart
To learn more about the main configuration file options, please review our official Nagios Core documentation here:
https://assets.nagios.com/downloads/nag ... gmain.html
benhank
Post by benhank »
hmm no command line eh? well maybe ill try using sed or awk in the script.
you can lock it bro and thanks for the info!
Proudly running:
Nagios Fusion
