Hey,
I’d like to use the check_by_ssh plugin (we are using XI but I think it uses the same for the SSH Proxy wizard) but I have a slightly difficult/different setup.
My security team won’t let me use a nagios user on managed hosts. We are using a service account (e.g. svcmon) for our monitoring and that account uses an authorized key that is pushed to all managed servers.
I’m not sure what I need to do so that I could use the SSH Proxy wizard. Is there a change that I can make to either change to the service account in place of the nagios account or ensure that the tool is using the authorized key?
check_by_ssh
Re: check_by_ssh
Hi Kevin,
check_by_ssh can use a different account/key file using the -l and -i options. From the help page:
-l, --logname=USERNAME
SSH user name on remote host [optional]
-i, --identity=KEYFILE
identity of an authorized key [optional]
...As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
