Hi guys/girls,
I need some assistance in how to setup a notification scheme.
Our company has a very basic approach on notifications and it baffles me to not understand how to do this in Nagios.
We are wanting to use the following scheme:
OnCall personnel:
V1 OnDuty
V2 OffDuty
Groups: P1 is primary responsible and P2 is secondary.
G1 08:00-16:00 Workdays P1=Bob, P2=John
G2 08:00-16:00 WorkDays P1=John, P2=Bob
G3 08:00-16:00 WorkDays P1=Larry, P2=John
Categories:
Critical1 Mail 00:00 – 24:00 SMS 00:00 - 24:00
Critical2 Mail 00:00 – 24:00 SMS 08:00 - 24:00
Critical3 Mail 00:00 – 24:00 SMS 08:00 - 16:00
Critical4 Mail 00:00 – 24:00 SMS 16:00 – 24:00
Critical5 Mail 00:00 – 24:00
I've tried to use contact templates where I setup the template to use host-command and service command to email with a time period of 24/7 and then another template to use Host command and Service command to send SMS 16:00 - 24:00 but when I apply those templates to one contact, only the top one is active... can you only apply 1 template to specify notification periods? How can I get around this problem? Is there another way of doing it I'm just not seeing?
Regards,
Dag Olav Tiller
per Service/Contact, Notification Periods/Using Templates
Reason: Better topic.
Re: Using Templates
You will need two contacts for each user, to fill in all the cells of your matrix that you'd need.
v1 X X X
v2 X X
John Bob Larry
Each X will have a different notification period, regardless of the person being the same since the notification is different it's a whole new contact. In XI this could just be done manually via the web interface, since this is so simple.
v1 X X X
v2 X X
John Bob Larry
