Hello Guys:
I'm having this recurrent error on /usr/local/nagiosxi/tmp/phpmailer.log
[10-27-2017 07:13:07] The following From address failed: [email protected] : MAIL FROM command failed,Message submission rate for this client has exceeded the configured limit
,421,4.4.2SMTP server error: MAIL FROM command failed Detail: Message submission rate for this client has exceeded the configured limit
SMTP code: 421 Additional SMTP info: 4.4.2SMTP server error: MAIL FROM command failed Detail: Message submission rate for this client has exceeded the configured limit
SMTP code: 421 Additional SMTP info: 4.4.2 (method=smtp;host=17X.XXX.XXX ;port=25;smtpauth=true;security=none), Referer: includes/components/xicore/xicore.inc.php > Event Handler Notification Email
after that i got a confirmation that email has been sent.
Exchange server is set to X message rate limit. This means that the Exchange server can only send X emails concurrently. When a large number of emails that exceed the limit go through the mail server, it will fail due to the limitation. https://confluence.atlassian.com/jirakb ... 93133.html
Do you have access to the Exchange server settings?
