NRPE: UNKNOWN Can't connect to the JVM
pmoradiya
Post by pmoradiya »
I have found seemingly inconsistent behavior of NRPE (v.3.2.1). I am running check_jvm plugin on the monitored hosts. All hosts have NRPE installed and configured exactly the same way. However, NRPE command on couple of hosts is not able to connect to JVM. Here is the info on config:
nrpe.cfg
command[check_tomcat_threads]=/usr/bin/sudo -u tomcat8 /usr/local/nagios/libexec/check_jvm -n org.apache.catalina.startup.Bootstrap -p threads -w 195 -c 225
sudoers file
nagios ALL=(ALL) NOPASSWD: /usr/local/nagios/libexec/
check_nrpe works as expected for other commands but not for check_jvm plugin
root@server1:/usr/local/nagios/libexec# ./check_nrpe -H localhost -c check_load
OK - load average: 0.00, 0.00, 0.00|load1=0.000;0.150;0.300;0; load5=0.000;0.100;0.250;0; load15=0.000;0.050;0.200;0;
root@server1:/usr/local/nagios/libexec# ./check_nrpe -H localhost -c check_tomcat8
PROCS OK: 1 process with UID = 112 (tomcat8) | procs=1;;1:5;0;
root@server1:/usr/local/nagios/libexec# ./check_nrpe -H localhost -c check_tomcat_threads
UNKNOWN Can't connect to the JVM:
If the command in nrpe.cfg is run on the shell, it works fine both as root user and nagios user. Hence, no issue with check_jvm plugin too.
root@server1:/usr/local/nagios/libexec# /usr/bin/sudo -u tomcat8 /usr/local/nagios/libexec/check_jvm -n org.apache.catalina.startup.Bootstrap -p threads -w 195 -c 225
OK 37 |threads=37;;;
I don't know what I am missing. I really appreciate your assistance with this.
Thanks.
pmoradiya
Re: NRPE: UNKNOWN Can't connect to the JVM
Post by pmoradiya »
Additional information from the debug log at /usr/local/nagios/var/nrpe.log
Showing WARNING as my_system() seteuid(0):Operation not permitted.
[1510171606] Connection from 127.0.0.1 port 14494
[1510171606] is_an_allowed_host (AF_INET): is host >127.0.0.1< an allowed host >127.0.0.1<
[1510171606] is_an_allowed_host (AF_INET): host is in allowed host list!
[1510171606] Host address is in allowed_hosts
[1510171606] Host 127.0.0.1 is asking for command 'check_tomcat_threads' to be run...
[1510171606] Running command: /usr/bin/sudo -u tomcat8 /usr/local/nagios/libexec/check_jvm -n org.apache.catalina.startup.Bootstrap -p threads -w 195 -c 225
[1510171606] WARNING: my_system() seteuid(0): Operation not permitted
[1510171606] Command completed with return code 3 and output: UNKNOWN Can't connect to the JVM:
[1510171606] Return Code: 3, Output: UNKNOWN Can't connect to the JVM:
[1510171606] Connection from 127.0.0.1 closed.
Post by mcapra »
Have you checked the permissions of JvmInspector.jar and validated that the tomcat8 user is able to execute it? That would be my first thought.
pmoradiya
Post by pmoradiya »
mcapra wrote:Have you checked the permissions of JvmInspector.jar and validated that the tomcat8 user is able to execute it? That would be my first thought.
Yes. It has the same permission as on the other server where it is working.
root@server2:/usr/local/bin# ls -l
-rw-r--r-- 1 root root 4714063 Nov  3 17:02 JvmInspector.jar
root@server1:/usr/local/bin# ls -lart
-rw-r--r--  1 root root 4714063 Nov  9 15:32 JvmInspector.jar
npolovenko
Post by npolovenko »
Hello, @pmoradiya.
Please make the following change in your sudoers file:
Change:
To:
nagios ALL=(ALL) NOPASSWD: /usr/local/nagios/libexec/check_jvm
Let us know if that fixes your issue.
pmoradiya
Post by pmoradiya »
npolovenko wrote:Hello, @pmoradiya.
Change:
To:
I updated the sudoers file as suggested but the same result.
pmoradiya
Post by pmoradiya »
Appreciate if anyone can point to any small or big part of configuration I might have missed.
Thanks.
npolovenko
@pmoradiya, Can you upload your nrpe.cfg file? Also, since you're running the check from the tomcat8 user, I'd add another line in the sudoers file:
tomcat8 ALL=(ALL) NOPASSWD: /usr/local/nagios/libexec/check_jvm
Keep us updated on this.
pmoradiya
Post by pmoradiya »
npolovenko wrote:@pmoradiya, Can you upload your nrpe.cfg file? Also, since you're running the check from the tomcat8 user, I'd add another line in the sudoers file:
I have also added this line to sudoers but same result.
I have attached nrpe.cfg
nrpe.cfg
(13.91 KiB) Downloaded 471 times
npolovenko
@pmoradiya, Can you manually switch to tomcat8 user and attempt to run the plugin?
 su - tomcat8
And then:
Does that work?
I'd also modify permissions for JvmInspector.jar to allow for tomcat8 user.
chown tomcat8 JvmInspector.jar
