I intend to display all cpu stats of all my nagios server from Nagios Fusion server . but the available dashlet only display the CPU stat of only the fusion server . I tried to edit the php code but I can't understand where it is querying its data from .
global $db;
$sysstat_rows = $db->exec_query('SELECT * FROM sysstat WHERE server_id = 0');
<?php
require_once(dirname(__FILE__) . '/../dashlet-helper.inc.php');
fusion_sysstat_dashlet();
function fusion_sysstat_dashlet() {
global $db;
$sysstat = array();
foreach ($sysstat_rows as $row) {
$metric = $row['metric'];
if (!in_array($metric, fusion_sysstat_array()))
continue;
$value = fusion_sysstat_value_to_array($row['value']);
$sysstat[$metric] = $value;
// need this for load calculations
$processor_count = intval(exec("cat /proc/cpuinfo | grep processor | wc -l"));
if ($processor_count <= 0)
$processor_count = 1;
<table class="table table-condensed table-striped table-bordered sysstat serverstat">
<thead>
<tr>
<th><?php echo _('Metric'); ?></th>
<th><?php echo _('Value'); ?></th>
<th class="visualize"></th>
</tr>
</thead>
<tbody>
<tr>
<th colspan="3"><?php echo _('Load'); ?></th>
</tr>
<tr>
<td><?php echo _('1 min'); ?></td>
<td><?php $load1 = fusion_sysstat_print_value($sysstat, 'load', 'load1') ?></td>
<td><?php fusion_sysstat_print_bar($load1, $processor_count, $processor_count, $processor_count * 2); ?></td>
</tr>
<tr>
<td><?php echo _('5 min'); ?></td>
<td><?php $load5 = fusion_sysstat_print_value($sysstat, 'load', 'load5') ?></td>
<td><?php fusion_sysstat_print_bar($load5, $processor_count, $processor_count, $processor_count * 2); ?></td>
</tr>
<tr>
<td><?php echo _('15 min'); ?></td>
<td><?php $load15 = fusion_sysstat_print_value($sysstat, 'load', 'load15') ?></td>
<td><?php fusion_sysstat_print_bar($load15, $processor_count, $processor_count, $processor_count * 2); ?></td>
</tr>
<tr>
<th colspan="3"><?php echo _('CPU Stats'); ?></th>
</tr>
<tr>
<td><?php echo _('User'); ?></td>
<td><?php $user = fusion_sysstat_print_value($sysstat, 'cpustat', 'user', ' %') ?></td>
<td><?php fusion_sysstat_print_bar($user, 0, 200, 200); ?></td>
</tr>
<tr>
<td><?php echo _('Nice'); ?></td>
<td><?php $nice = fusion_sysstat_print_value($sysstat, 'cpustat', 'nice', ' %') ?></td>
<td><?php fusion_sysstat_print_bar($nice, 0, 200, 200); ?></td>
</tr>
<tr>
<td><?php echo _('System'); ?></td>
<td><?php $system = fusion_sysstat_print_value($sysstat, 'cpustat', 'system', ' %') ?></td>
<td><?php fusion_sysstat_print_bar($system, 0, 200, 200); ?></td>
</tr>
<tr>
<td><?php echo _('I/O Wait'); ?></td>
<td><?php $iowait = fusion_sysstat_print_value($sysstat, 'cpustat', 'iowait', ' %') ?></td>
<td><?php fusion_sysstat_print_bar($iowait, 0, 10, 20); ?></td>
</tr>
<tr>
<td><?php echo _('Steal'); ?></td>
<td><?php $steal = fusion_sysstat_print_value($sysstat, 'cpustat', 'steal', ' %') ?></td>
<td><?php fusion_sysstat_print_bar($steal, 0, 200, 200); ?></td>
</tr>
<tr>
<td><?php echo _('Idle'); ?></td>
<td><?php $idle = fusion_sysstat_print_value($sysstat, 'cpustat', 'idle', ' %') ?></td>
<td><?php fusion_sysstat_print_bar($idle, 0, 200, 200); ?></td>
</tr>
<tr>
<th colspan="3"><?php echo _('Memory'); ?></th>
</tr>
<tr>
<td><?php echo _('Total'); ?></td>
<td><?php $total = fusion_sysstat_print_value($sysstat, 'memory', 'total', ' MB') ?></td>
<td></td>
</tr>
<tr>
<td><?php echo _('Used'); ?></td>
<td><?php $used = fusion_sysstat_print_value($sysstat, 'memory', 'used', ' MB') ?></td>
<td><?php fusion_sysstat_print_bar($used, $total, $total * 2, $total * 2); ?></td>
</tr>
<tr>
<td><?php echo _('Free'); ?></td>
<td><?php $free = fusion_sysstat_print_value($sysstat, 'memory', 'free', ' MB') ?></td>
<td><?php fusion_sysstat_print_bar($free, $total, $total * 2, $total * 2); ?></td>
</tr>
<tr>
<td><?php echo _('Shared'); ?></td>
<td><?php $shared = fusion_sysstat_print_value($sysstat, 'memory', 'shared', ' MB') ?></td>
<td><?php fusion_sysstat_print_bar($shared, $total, $total * 2, $total * 2); ?></td>
</tr>
<tr>
<td><?php echo _('Buffers'); ?></td>
<td><?php $buffers = fusion_sysstat_print_value($sysstat, 'memory', 'buffers', ' MB') ?></td>
<td><?php fusion_sysstat_print_bar($buffers, $total, $total * 2, $total * 2); ?></td>
</tr>
<tr>
<td><?php echo _('Cached'); ?></td>
<td><?php $cached = fusion_sysstat_print_value($sysstat, 'memory', 'cached', ' MB') ?></td>
<td><?php fusion_sysstat_print_bar($cached, $total, $total * 2, $total * 2); ?></td>
</tr>
<tr>
<th colspan="3"><?php echo _('Swap'); ?></th>
</tr>
<tr>
<td><?php $total = fusion_sysstat_print_value($sysstat, 'swap', 'total', ' MB') ?></td>
<td></td>
</tr>
<tr>
<td><?php $used = fusion_sysstat_print_value($sysstat, 'swap', 'used', ' MB') ?></td>
<td><?php fusion_sysstat_print_bar($used, $total, $total * 0.33, $total * 0.5); ?></td>
</tr>
<tr>
<td><?php $free = fusion_sysstat_print_value($sysstat, 'swap', 'free', ' MB') ?></td>
</tr>
</tbody>
</table>
<?php
function fusion_sysstat_print_value($server, $arr, $subsys, $var, $suffix = '') {
$number = 0;
if (isset($arr["sysstat_{$subsys}"][$var])) {
$number = $arr["sysstat_{$subsys}"][$var];
echo get_formatted_number($number, 2) . $suffix;
else
echo _('N/A');
return $number;
function fusion_sysstat_print_bar($val, $max, $warn, $crit) {
$val = (float) $val;
$max = (float) $max;
if ($val > $max && $max > 0)
$val = $max;
$width = $val;
if ($max > 0)
$width = ($val / $max) * 100;
$color_ok = "#5CDF45";
$color_warn = "#FEFF6F";
$color_crit = "#FF795F";
$color = "background-color: {$color_ok};";
if ($val >= $warn)
$color = "background-color: {$color_warn};";
if ($val >= $crit)
$color = "background-color: {$color_crit};";
echo '<div style="height: 100%; width: ' . $width . '%;' . $color . '"> </div>';
function fusion_sysstat_array() {
return array(
'sysstat_cpustat',
'sysstat_load',
'sysstat_memory',
'sysstat_swap',
function fusion_sysstat_value_to_array($value) {
return unserialize(base64_decode($value));
