where perf data are stored?
Francesco
Post by Francesco »
Hi all,
the perf data are stored only in the RRD files under /usr/local/nagios/share/perfdata/ or also in the databases?
If presents also in the databases, in which table?
P.S. We have an old installation migrated to 5.4.11, so MySQL+PostgreSQL
dwasswa
Re: where perf data are stored?
Post by dwasswa »
Hi @Francesco,
If you are looking for historical perfdata, Nagios stores it in RRD and XML files.
However, the last perfdata is also stored in the perfdata column in the nagios_servicestatus table in the nagios database
Did you have any issue related to perfdata from your upgrade to 5.4.11 that you are trying to troubleshoot?
npolovenko
Post by npolovenko »
Thanks, @dwasswa! @Francesco, Do you have any other questions for us before I close the thread?
Francesco
Post by Francesco »
Thank you,
the thread can be closed.
