Problem SNMP UNKNOWN
sofiane
Post by sofiane »
Hello, I have a problem with snmp services. Indeed, each of them are "unknown" and i have an "error in packet"
I think I have well configured, I don't understand what is the real problem.
I installed packets "nagios-snmp-plugins" "nagios-plugins" "snmpd" "snmp"
I provide you my "nagios.cfg", "localhost.cfg", "commands.cfg", "templates.cfg"
nagios.tar.gz
my files
(18.51 KiB) Downloaded 661 times
Thanks for your help
Re: Problem SNMP UNKNOWN
Post by mcapra »
To satisfy my own selfish curiosity, is there a particular reason you're using SNMP to gather metrics from the local machine?
"Error in packet" is a message generated by the snmpd agent. Generally it means the OIDs you're querying are unavailable. I would double-check the scope that the "public" community has within your snmpd configuration as well as making sure that the UCD-SNMP-MIBs module is correctly exposed by the snmpd agent.
sofiane
Post by sofiane »
I use snmp in localhost services, just for a snmp test (to see if it works).
Why ? I shouldn't do it ?
rhassing
Post by rhassing »
SNMP is nice, so you could use it everywhere (that's my opinion) :-)
But could you try the following command on the command line:
snmpwalk -v2c -c public 127.0.0.1
And see if that works...
If that works, you could also try the following commands:
snmpget -v2c -c public 127.0.0.1 sysUpTime.0
and
snmpget -v2c -c public 127.0.0.1 .1.3.6.1.2.1.1.3.0
The last one tells you if there might be a problem with the MIB files. It's actually the same command, but with the full OID instead of using the MIB files.
Rob Hassing
sofiane
Post by sofiane »
I tried your commands.
1st command result :
iso.3.6.1.2.1.1.1.0 = STRING: "Linux Sofiane 4.9.0-4-amd64 #1 SMP Debian 4.9.65-3 (2017-12-03) x86_64"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.8072.3.2.10
iso.3.6.1.2.1.1.3.0 = Timeticks: (2178444) 6:03:04.44
iso.3.6.1.2.1.1.4.0 = STRING: "Me <[email protected]>"
iso.3.6.1.2.1.1.5.0 = STRING: "Sofiane"
iso.3.6.1.2.1.1.6.0 = STRING: "Sitting on the Dock of the Bay"
iso.3.6.1.2.1.1.7.0 = INTEGER: 72
iso.3.6.1.2.1.1.8.0 = Timeticks: (50) 0:00:00.50
iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.11.3.1.1
iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.15.2.1.1
iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.10.3.1.1
iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.1
iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.6.3.16.2.2.1
iso.3.6.1.2.1.1.9.1.2.6 = OID: iso.3.6.1.2.1.49
iso.3.6.1.2.1.1.9.1.2.7 = OID: iso.3.6.1.2.1.4
iso.3.6.1.2.1.1.9.1.2.8 = OID: iso.3.6.1.2.1.50
iso.3.6.1.2.1.1.9.1.2.9 = OID: iso.3.6.1.6.3.13.3.1.3
iso.3.6.1.2.1.1.9.1.2.10 = OID: iso.3.6.1.2.1.92
iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB for Message Processing and Dispatching."
iso.3.6.1.2.1.1.9.1.3.2 = STRING: "The management information definitions for the SNMP User-based Security Model."
iso.3.6.1.2.1.1.9.1.3.3 = STRING: "The SNMP Management Architecture MIB."
iso.3.6.1.2.1.1.9.1.3.4 = STRING: "The MIB module for SNMPv2 entities"
iso.3.6.1.2.1.1.9.1.3.5 = STRING: "View-based Access Control Model for SNMP."
iso.3.6.1.2.1.1.9.1.3.6 = STRING: "The MIB module for managing TCP implementations"
iso.3.6.1.2.1.1.9.1.3.7 = STRING: "The MIB module for managing IP and ICMP implementations"
iso.3.6.1.2.1.1.9.1.3.8 = STRING: "The MIB module for managing UDP implementations"
iso.3.6.1.2.1.1.9.1.3.9 = STRING: "The MIB modules for managing SNMP Notification, plus filtering."
iso.3.6.1.2.1.1.9.1.3.10 = STRING: "The MIB module for logging SNMP Notifications."
iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.6 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.7 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.8 = Timeticks: (49) 0:00:00.49
iso.3.6.1.2.1.1.9.1.4.9 = Timeticks: (50) 0:00:00.50
iso.3.6.1.2.1.1.9.1.4.10 = Timeticks: (50) 0:00:00.50
iso.3.6.1.2.1.25.1.1.0 = Timeticks: (4154087) 11:32:20.87
iso.3.6.1.2.1.25.1.2.0 = Hex-STRING: 07 E1 0C 0D 12 30 19 00 2B 01 00
iso.3.6.1.2.1.25.1.3.0 = INTEGER: 393216
iso.3.6.1.2.1.25.1.4.0 = STRING: "BOOT_IMAGE=/boot/vmlinuz-4.9.0-4-amd64 root=UUID=415d6a07-bd43-4437-9d2d-15d8bdd04a63 ro quiet
iso.3.6.1.2.1.25.1.5.0 = Gauge32: 1
iso.3.6.1.2.1.25.1.6.0 = Gauge32: 175
iso.3.6.1.2.1.25.1.7.0 = INTEGER: 0
iso.3.6.1.2.1.25.1.7.0 = No more variables left in this MIB View (It is past the end of the MIB tree)
2nd command result :
sysUpTime.0: Unknown Object Identifier (Sub-id not found: (top) -> sysUpTime)
3rd command result :
iso.3.6.1.2.1.1.3.0 = Timeticks: (2182761) 6:03:47.61
rhassing
Post by rhassing »
There seems to be a problem with your MIB files.
Did you install net-snmp-libs package?
That's where the MIB files are in.
In Centos / Fedora the MIB are normally installed in:
/usr/share/snmp/mibs/
Rob Hassing
sofiane
Post by sofiane »
No, I just installed "nagios-snmp-plugins" "nagios-plugins" "snmpd" "snmp".
Edit : I installed it
kyang
Post by kyang »
Sounds good,
Is it still having the same SNMP unknown error once you installed?
sofiane
Post by sofiane »
rhassing
Post by rhassing »
Is there a difference when you run the commands I mentioned before?
Rob Hassing
