Can I modify loginsplash.png above the login page ?
How to do ?
bolson
Re: about login page loginsplash.png
Hello Olin,
The easiest way to accomplish is to rename loginsplash.png, save the image you wish to use as a png file and name it loginsplash.png and drop it into the /usr/local/nagiosxi/html/images/ folder on your XI host. Let me know if this resolves your issue.
Thank you.
Thank you.
ok , thanks !!
bolson wrote:Hello Olin,
Thank you.
npolovenko
- Support Tech
Locking the thread as resolved.
