Hello:
I have installed Nagios XI 5.4.1.1 and then just upgraded to 5.4.1.2 a few minutes ago - I am not reporting any issues with functionality.
I just noticed that when, specifically after installing 5.4.1.1 and 5.4.1.2, while running the Windows Server Wizard, one can download NSClient++ 0.4.4 in Step 2 (provided in attachment "Windows_Config_Agent_Step2.jpg"), but then the final step provides the older versions (provided in attachment "Windows_Config_Agent_Final_Step.JPG")
Just something that needed to be brought to someone's attention.
Something that may need to be fixed ...
Newbie '14
Re: Something that may need to be fixed ...
I was able to recreate the issue, and filed an internal bug report (task id 12913). Thank you for reporting it!
