Install problem under Ubuntu 16.04 LTS
Dalamir
Post by Dalamir »
Hi All,
Tried to install via ./fullinstall, but the installation halts during .11-sourceguardian.
Unable to start apache2 because of syntax error in apache2.conf.
It turns out /etc/apache2/conf-enabled contains an empty nagios3.conf.
Tried to find an example of what should be in the file, but unsuccesfully.
Any thoughts?
Regards
Re: Install problem under Ubuntu 16.04 LTS
Nagios XI installs on Ubuntu are not supported yet. The only supported distributions are CentOS 6/7 and RHEL 6/7.
https://support.nagios.com/kb/article/n ... ts-12.html
