Nagios XI yum update
vec
Post by vec »
Hi i have a question with yum updates on Nagios XI. When I run yum update i get:
Is this ok [y/N]: y
Downloading Packages:
warning: rpmts_HdrFromFdno: Header V4 RSA/SHA1 Signature, key ID c62934a0: NOKEY
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NAGIOS
The GPG keys listed for the "Nagios" repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.
I have never see that message on Nagios server.
Is it OK to run yum update?
Thank You
Re: Nagios XI yum update
Run the following command from the CLI:
yum update nagios-repo -y
or go to: https://repo.nagios.com/?repo=rpm-centos and install the new rpm.
Did this help?
vec
Post by vec »
Yes, that did the trick, no more warning or error.
I am glad I was able to help! I will be closing this topic now. If you have any more questions/issues, please start a new thread.
