NagiosXI upgrade to 5.4.13 does not update version
sib
Post by sib »
Hi
I have done the upgrade using the upgrade script provided by the binary. Given it is a RPM install it updated the nagiosxi rpms
# ./upgrade
RPM Install detected, switching to yum update
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-disabled-repos, subscription-manager
BIS_Centrify_Centrify        | 2.1 kB  00:00:00
BIS_EPEL_EPEL_7        | 2.1 kB  00:00:00
BIS_Nagios_Nagios_Deps_RHEL7        | 2.1 kB  00:00:00
BIS_Nagios_Nagios_RHEL_7        | 2.1 kB  00:00:00
rhel-7-server-extras-rpms        | 2.0 kB  00:00:00
rhel-7-server-optional-rpms        | 2.0 kB  00:00:00
rhel-7-server-rh-common-rpms        | 2.1 kB  00:00:00
rhel-7-server-rpms        | 2.0 kB  00:00:00
rhel-7-server-satellite-tools-6.2-rpms        | 2.1 kB  00:00:00
rhel-server-rhscl-7-rpms        | 2.0 kB  00:00:00
No packages marked for update
Uploading Enabled Repositories Report
Loaded plugins: product-id, subscription-manager
This is the rpm version
# rpm -qa | grep nagiosxi
nagiosxi-wmic-5-4.13.el7.x86_64
nagiosxi-ndoutils-5-4.13.el7.x86_64
nagiosxi-nagiosplugins-5-4.13.el7.x86_64
nagiosxi-nagioscore-5-4.13.el7.x86_64
nagiosxi-nagiosmobile-5-4.13.el7.x86_64
nagiosxi-nrpe-5-4.13.el7.x86_64
nagiosxi-ajaxterm-5-4.13.el7.x86_64
nagiosxi-pnp-5-4.13.el7.x86_64
nagiosxi-nsca-5-4.13.el7.x86_64
nagiosxi-nagiosql-5-4.13.el7.x86_64
nagiosxi-5-4.13.el7.x86_64
nagiosxi-nrds-5-4.13.el7.x86_64
nagiosxi-wkhtmltox-5-4.13.el7.x86_64
nagiosxi-nagvis-5-4.13.el7.x86_64
nagiosxi-mrtg-5-4.13.el7.x86_64
The website still shows 5.4.11. I have restarted the server and I cleared the browsercache. Is there a command line command to check the installed version?
Re: NagiosXI upgrade to 5.4.13 does not update version
you are missing the base package
Try installing this directly and look for errors
sib
Post by sib »
It is in the list of packages I posted.
Wow sorry, my eyes must not be working, lets re-install that RPM, that is the one that will make the changes, and if it can't write the files it should error in the output (but it will go by fast and you may have to scroll up to see the error)
sib
Post by sib »
No problem :D
The
yum reinstall nagiosxi
has actually worked.
best
Chris
Excellent! glad to hear it is resolved.
