change the default check from ping to something else
aristosv
Post by aristosv »
This is the host definition for one of the servers I want to monitor.
define host {
	use linux-server
	host_name srv001
	address 192.168.15.53
	hostgroups hostgroup1
	host_name srv001
	service_description process
	check_command check_remote_process
Under Current Status > Services, I can see that the "check_remote_process" check for this host working just fine.
But under Current Status > Hosts, the default check is ping, and this server is configured NOT to reply to pings.
How/where do I change the default check for this server to something else, besides ping? Is there an option to change this for all the servers using a universal setting, so I don't have to make a change on all the hosts definitions?
Re: change the default check from ping to something else
being there isn't a check_command specified it must be specified in the template
this is a template
use linux-server
And that definition could contain other templates.
BUt to override it you can add the command right to the host
check_command     your_other_check
aristosv
Post by aristosv »
thanks, that did it.
Great. Locking thread.
