Availability Report pbm
leens
Post by leens »
Hello
In 2011 R1.9 I have problem that I have 0.000 in place of host name. I see it was a bug in R1.8 but I have this in R1.9
Re: Availability Report pbm
this is a known bug that is fixed in the next release. If you would like to fix it before then you can do the following:
open the file /usr/nagiosxi/html/reports/availability.php
on line 895 change
echo "<td>".number_format($hn,3)."  </td>";
to
echo "<td>".$hn."  </td>";
and on line 941 change
echo "<td>".number_format($sd,3)."  </td>";
to
echo "<td>".$sd."  </td>";
leens
Post by leens »
Thanks a lot
This is also fixed in 2011R2.0
