Thanks Scott. I tried your suggestion and while it also made sense to me. It didn't work. As well, no I have confirmation it will work at all. I have tried every single one off of exchange and neither of them get me close except for
check_ntlmauth.pl which produces these results:
[[email protected] ~]$ /usr/local/nagios/libexec/check_ntlmauth.pl -u thehive.domain.com/Pages/Home.aspx -l user -p pass123 -e 'The Hive' -d -s
500 Can't connect to thehive.domain.com:443 (connect: Connection refused)
Content-Type: text/plain
Client-Date: Tue, 17 Apr 2018 16:15:54 GMT
Client-Warning: Internal response
HTTPAUTH CRITICAL: authentication failed
Now this is pretty obvious because I have no binding to 443 only 80. I have no idea how to change it to to use http. The script is below; you will find I have declared it to use port 80 where it was previously 443. However, it is still trying on port 443 SSL. I do not want to host the site on 443...
#!/usr/bin/perl
# FILE: check_ntlmauth.pl
# USAGE: check_ntlmauth.pl -u <url> -l <username> -p <password> (-c <critical> -w <warning> -e <expect> -v)
# DESCRIPTION: Authenticates against a web page using ntlm auth
# OPTIONS: ---
# REQUIREMENTS: LWP::UserAgent, Authen::NTLM, LWP::Authen::Ntlm and Crypt::SSLeay if https support is required
# BUGS: If the webpage is not using ntlm auth you may get false positives
# NOTES: ---
# AUTHOR: Tim Pretlove
# VERSION: 0.6
# CREATED: 16-06-2010
# REVISION: ---
# LICENCE: GNU
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
use strict;
use warnings;
use LWP::UserAgent;
use HTTP::Request::Common;
#use LWP::Debug qw(+);
use Getopt::Long;
use Time::HiRes qw(gettimeofday tv_interval);
use LWP::Authen::Ntlm;
use Authen::NTLM;
use lib "/usr/local/nagios/libexec";
use utils qw(%ERRORS);
my $domain = "cafaroco";
my ($status,$debug,$login,$crit,$warn,$ver,$expect,$url,$passwd);
GetOptions(
'crtitical=s' => \$crit,
'warning=s' => \$warn,
debug => \$debug,
status => \$status,
verbose => \$ver,
'url=s' => \$url,
'login=s' => \$login,
'password=s' => \$passwd,
'expect=s' => \$expect) or HELP_MESSAGE();
sub testauth {
my ($status,$debug,$login,$crit,$warn,$ver,$expect,$url,$passwd) = @_;
my $elapsed;
my $startsec;
my $ua = new LWP::UserAgent(keep_alive=>1);
my $newlogin = $domain . '\\' . $login;
$ua->credentials("$url:80", '',$newlogin, $passwd);
$ua->cookie_jar ( {} );
#$ua->requests_redirectable;
my $timeout = $crit + 1;
$ua->timeout($timeout);
$startsec = [gettimeofday()];
my $httpchk = substr $url, 0, 4;
if ($httpchk ne "http") { $url = "https://" . $url } else {
print "Please do not put a http:// or https:// prefix on the address\n";
HELP_MESSAGE();
my $req = GET $url;
print $req->content;
my $response = $ua->request($req);
$elapsed = tv_interval ($startsec, [gettimeofday]);
if ($debug) {
my $str = $response->content;
print "$str\n";
if ($status) {
my $str = $response->status_line;
print "$str\n";
print $response->headers()->as_string(), "\n";
if ($response->is_success) {
if (defined $expect) {
if ($str !~ /$expect/) {
return (4,$elapsed);
if ((defined $crit) && (defined $warn)) {
if ($crit <= $elapsed) { return 3,$elapsed }
if ($warn <= $elapsed) { return 2,$elapsed }
return 0,$elapsed;
} else { return 1,$elapsed }
sub HELP_MESSAGE {
print "$0 -u <url> -l <username> -p <password> (-c <critical> -w <warning> -e <expect> -v)\n";
print "\t -u <url> # url string to run basic auth against do not prefix with http or https\n";
print "\t -l <username> # username to login with\n";
print "\t -p <password> # password to login with\n";
print "\t -c <seconds> # the number of seconds to wait before a going critical\n";
print "\t -w <seconds> # the number of seconds to wait before a flagging a warning\n";
print "\t -v # displays nagios performance information\n";
print "\t -e <expect> # string to query on the authenticated page\n";
print "\t -s prints status line (debugging info)\n";
print "\t -d prints page contents (debugging info)\n";
print "\t e.g $0 -u foobar.com -l testuser -p testpasswd -c 10 -w 3 -v -e \"Hello sweetie\"\n";
exit 0;
sub checkopts {
if ((!defined $url) || (!defined $login) || (!defined $passwd)) {
print "Missing argument ";
if (!defined $url) { print "-u <url>" }
if (!defined $login) { print "-l <username> " }
if (!defined $passwd) { print "-p <password>" }
print "\n";
HELP_MESSAGE();
exit 4;
if ((defined $ver) && ((!defined $crit) || (!defined $warn))) {
print "-v needs -c and -w values to be specified\n";
HELP_MESSAGE();
exit 4;
if (((defined $warn) && (!defined $crit)) || ((defined $crit) && (!defined $warn))) {
print "Both -w and -c need to be specified\n";
HELP_MESSAGE();
exit 4;
checkopts($status,$debug,$login,$crit,$warn,$ver,$expect,$url,$passwd);
my ($rc,$eltime) = testauth($status,$debug,$login,$crit,$warn,$ver,$expect,$url,$passwd);
my @mess = qw(OK CRITICAL WARNING CRITICAL CRITICAL);
my @mess2 = ("host authenticated successfully","authentication failed","is slow responding","host critical response time","failed to retrieve expect string");
print "HTTPAUTH $mess[$rc]: $mess2[$rc]";
if (defined $ver) {
print "|time=$eltime" . "s;$warn;$crit;0;$crit";
print "\n";
exit $ERRORS{$mess[$rc]};
