Hello Support,
I am trying to migrate my nagiosxi installation to a new server and while trying to restore the DB to the new server I get the following error
ERROR 2006 (HY000) at line 186: MySQL server has gone away
Error restoring MySQL database 'nagiosxi' !.....
Below are the steps I am using for the migration:
...I spun up a new server and:
cd into the /tmp/ directory
then
wget {XI 5.2.3 tar}(you can find the download link in the list below):
https://www.nagios.com/downloads/nagios ... -releases/
tar xzf name_of_the_downloaded_tar
cd into it
./fullinstall
https://assets.nagios.com/downloads/nag ... -Linux.pdf
Then you'd backup the old XI system, use filezilla or winscp to transfer the backup tar.gz over to the new server and restore from that backup.
https://assets.nagios.com/downloads/nag ... ios-XI.pdf....
Your support will be helpful.
Error while restoring Database to a new server
venturegardengroup
- tacolover101
Re: Error while restoring Database to a new server
how large is the database file you're attempting to restore?
from what i can tell, this may be related to an import exceeding size, or a connection timeout. some of the suggestions here may help you - https://stackoverflow.com/questions/104 ... -gone-away
npolovenko
- Support Tech
@venturegardengroup, I see you have opened a ticket for the same issue in our ticketing system, so I will be closing this thread. In the future please only open one or the other so we can focus our efforts. Thank you!
