Hi all.
Is there a way in Nagios XI to enable the WithPeak MRTG option for a bunch of devices? My client would like to use Nagios to assist in planning future architecture and would to see the 5m peaks as well as the average.
MRTG WithPeak option
cwscribner
Re: MRTG WithPeak option
this is actually already enabled by default. The settings are in
/usr/local/nagios/pnp/rra.cfg
You must note that there is not "peak" unless you are looking at a time scale long enough that all points aren't already shown. So if you click the graph and choose a longer timescale, you should see the peaks.
# PNP default RRA config
# you will get 400kb of data per datasource
# 2880 entries with 1 minute step = 48 hours
RRA:AVERAGE:0.5:1:2880
# 2880 entries with 5 minute step = 10 days
RRA:AVERAGE:0.5:5:2880
# 4320 entries with 30 minute step = 90 days
RRA:AVERAGE:0.5:30:4320
# 5840 entries with 360 minute step = 4 years
RRA:AVERAGE:0.5:360:5840
RRA:MAX:0.5:1:2880
RRA:MAX:0.5:5:2880
RRA:MAX:0.5:30:4320
RRA:MAX:0.5:360:5840
RRA:MIN:0.5:1:2880
RRA:MIN:0.5:5:2880
RRA:MIN:0.5:30:4320
RRA:MIN:0.5:360:5840
cwscribner
Thanks! Question answered.
