Warning: Duplicate definition found for contact 'xi_default_contact' (config file '/usr/local/nagios/etc/contacts.cfg', starting on line 70)
Error: Could not add object property in file '/usr/local/nagios/etc/contacts.cfg' on line 71.
everytime i am deleting the entries but still it is showing the same errors.
Error
Re: Error
Are you deleting them through the XI web UI or through the file?
Re: Error
Out of curiosity, why couldn't you delete them is XI? Did you get an error?srikanth wrote:I am deleting in the file as i couldn't delete them through XI.
The proper way, would be to go to
Config -> Core Config Manager -> Contacts -> Delete
If you don't drmove them through XI they will be re-created when the config is applied.
