Monitoring Docker containers
jankogaga
Re: Monitoring JMX
Post by jankogaga »
Could you take a look at attached /usr/local/nagios/etc/nrpe.cfg?
I wondered if server_address=127.0.0.1 is ok since with server_address=10.30.30.33
I got the error in /usr/local/nagios/var/nrpe.log when starting nrpe daemon:
Bind to port 5666 on 10.30.30.33 failed: Cannot assign requested address.
nrpe.cfg
(12.31 KiB) Downloaded 290 times
Re: Monitoring JMX
Actually I would comment the server_address out completely, then restart nrpe...
you want it to bind to all interfaces for now.
ahumandesign.com
enneagrams.com
jankogaga
Re: Monitoring JMX
Post by jankogaga »
That did the trick.
Now, monitoring JMX works as expected.
Since this thread is more related to setting nrpe within docker, I wondered if you can change the title
from Monitoring JMX to something else.
Thank you very much!
Re: Monitoring Docker containers
I changed the title to "Monitoring Docker containers"
Glad it's working... Locking
ahumandesign.com
enneagrams.com
