Creating Dashlet & Components
lizhi1989
Post by lizhi1989 »
Does creating dashlets & components using existing xi/fusion codes (with modification) allowed?
Re: Creating Dashlet & Components
I would think so - that's the best way to get started, but the Nagios folks will know for sure.
lizhi1989 wrote:Does creating dashlets & components using existing xi/fusion codes (with modification) allowed?
Yes you can create custom dashlets and components, that utilize existing functions call. However, you should NOT modify the code in XI or fusion outsid eof your dashlet or component as this not only could break your install, it would be overridden on your next upgrade.
All changes should be contained within your component or dashlet code.
lizhi1989
Post by lizhi1989 »
Thank you for the reply, we understand the risk of breaking the installation and been overridden on upgrade.
Unfortunately, we need to make necessary amendments according to our users' need.
lizhi1989 wrote:Thank you for the reply, we understand the risk of breaking the installation and been overridden on upgrade.
Then it is allowed on licensed versions as long as you are not modifying any sourceguardian encrypted filed.
