Hi, I just upgraded to the new version of XI and I have rebooted several times. But whenever I login to the web console, all of the data information fields have a spinning progress indicator. They never stop spinning and show me any data.
Also, I bought a license, but don't have access to the customer support forum for some reason.
Dumont
Upgrade failed
Re: Upgrade failed
This is possibly a javascript cache problem, can I have you try to clear your browser cache and try accessing the page again. Thif this doesn't resolve the problem can I have you check the apache error log.ordwaycenter wrote:Hi, I just upgraded to the new version of XI and I have rebooted several times. But whenever I login to the web console, all of the data information fields have a spinning progress indicator. They never stop spinning and show me any data.
tail -f /var/log/httpd/error_logPlease contact [email protected] and they can get your access to the customer forum setup.ordwaycenter wrote:Also, I bought a license, but don't have access to the customer support forum for some reason.
Re: Upgrade failed
Thanks for the heads up. When we compressed the javascript scripts it created an issue with IE and Chrome loading the dashlets correctly. The fixed tarball is being uploaded as we speak, and should be ready to download about 30 minutes after this post. Go ahead and download the tarball once more and run the upgrade, it should resolve the issue.
ordwaycenter
Re: Upgrade failed
That fixed it. Thanks
Re: Upgrade failed
Great!
