Nagios log server not receving logs
syedali
Post by syedali »
Hi Support Team,
We've encountered an error in our Nagios log server where in the server is not receiving logs from sources.
What I 've tried so far:
1) checked the config file /etc/rsyslog.d/99-nagioslogserver.conf the entry shows *.*localhost:5544
2) checked if Firewall is not blocking the traffic
3) rsyslog service shows as active, followed by an error as follows :
4) Followed the KB but no luck :https://support.nagios.com/kb/article.php?id=38
rsyslogd[107876]: cannot connect to servername:5544: Connection refused [v8.35.0 try htt
p://www.rsyslog.com/e/2027 ]
rsyslog debug logs.txt
attached are the debug and logstash logs for your reference. Your help on this will be much appreciated.
Logstash logs:
Error Logs:
rsyslog_error.txt
Syed
cdienger
Re: Nagios log server not receving logs
Post by cdienger »
There are problems with logstash being able to bind to 5544 as 5544 appears to already be in use. Try stopping logstash with:
service logstash stop
make sure that port 5544 is not being used:
netstat -nap | grep 5544
and if that doesn't show port 5544 in use, restart logstash with:
service logstash start
jslawrenc
Post by jslawrenc »
I work with Syed and we were able to get to root cause yesterday. Entries were added in the core config which seemed to create conflicts.
Possibly a port being defined twice. What made this challenging is LMS seem to run for days under this config and the error logs we audited somewhat put us on a wild goose chase. Just sharing what we found in case anyone trips over this down the road.
jslawrenc wrote:I work with Syed and we were able to get to root cause yesterday. Entries were added in the core config which seemed to create conflicts.
Thanks for coming back and sharing your findings
