NagiosXI R2.0 upgrade error?
SDohmen
Post by SDohmen »
During the upgrade of R2.0 i noticed the following:
RET: 0
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
SETUID ROOT OK
RESETTING PERMS
/usr/local/nagiosxi/nom/checkpoints/nagioscore /tmp/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
NAGIOSQL-POST
Archive:  sourceguardian/ixed4.lin.x86-32.zip
  inflating: ixed.5.3.lin
No valid Sourceguardian extension found for PHP version 5.3
[root@centraldev nagiosxi]# /tmp/nagiosxi/nagiosxi/basedir/scripts
After this the cursor just stands there. Is this normal behaviour of the upgrade process?
SDohmen
Re: NagiosXI R2.0 upgrade error?
Post by SDohmen »
I found another error.
When you goto unconfigured objects and you try to use the small select box on top (the one that selects all), nothing happens. When you click a host/service select box it works just fine.
The "No valid Sourceguardian extension found for PHP version 5.3" error has been fixed and the updated version *should* be available within the next few days. I haven't been able to recreate the "select all box" error. It works fine on mine - I tested it in Firefox 10.0, IE 9, and Chrome 16. What browser are you using? Did you try clearing your browser's cache?
SDohmen
Post by SDohmen »
lmiltchev wrote:The "No valid Sourceguardian extension found for PHP version 5.3" error has been fixed and the updated version *should* be available within the next few days. I haven't been able to recreate the "select all box" error. It works fine on mine - I tested it in Firefox 10.0, IE 9, and Chrome 16. What browser are you using? Did you try clearing your browser's cache?
I tried it on a FF10 without cache enabled. But i have the same problem on internet explorer. To be sure i will try it again tomorrow.
We've got a minor release posted (install and upgrade fixes only) posted. Here's the download link.
http://assets.nagios.com/downloads/nagi ... 2.1.tar.gz
