No performance data (graphs) found for NRDP passive checks
dlukinski
Post by dlukinski »
Hello Nagios Support
We are no getting any performance data for the passive NRDP-based checks (or the host checks)
How to troubleshoot this issue?
Thank you
Re: No performance data (graphs) found for NRDP passive chec
How are you sending them?
dlukinski
Post by dlukinski »
scottwilkerson wrote:How are you sending them?
I could show if we schedule a meeting (from Nagios CORE to Nagios XI)
Are you sending via nagios command?
If it is from within Nagios, are you passing the $HOSTPERFDATA$ & $SERVICEPERFDATA$ to the command?
dlukinski
Post by dlukinski »
scottwilkerson wrote:Are you sending via nagios command?
Please take a look at CORE config files attached
- citrix.cfg is the example of the monitoring done VS the portals (other monitoring would be similar to it)
change these commands
command_name send_nrdp_host
command_line $USER1$/send_nrdp.php --url=http://10.96.30.40/nrdp/ --token=nagiosxi40 --host="$HOSTNAME$" --state=$HOSTSTATEID$ --output="$HOSTOUTPUT$"
command_name send_nrdp_service
command_line $USER1$/send_nrdp.php --url=http://10.96.30.40/nrdp/ --token=nagiosxi40 --host="$HOSTNAME$" --service="$SERVICEDESC$" --state=$SERVICESTATEID$ --output="$SERVICEOUTPUT$"
to this
command_line $USER1$/send_nrdp.php --url=http://10.96.30.40/nrdp/ --token=nagiosxi40 --host="$HOSTNAME$" --state=$HOSTSTATEID$ --output="$HOSTOUTPUT$|$HOSTPERFDATA$"
command_line $USER1$/send_nrdp.php --url=http://10.96.30.40/nrdp/ --token=nagiosxi40 --host="$HOSTNAME$" --service="$SERVICEDESC$" --state=$SERVICESTATEID$ --output="$SERVICEOUTPUT$|$SERVICEPERFDATA$"
dlukinski
Post by dlukinski »
scottwilkerson wrote:change these commands
to this
This fixed the issue
Thank you so much!
I am glad your issue has been resolved! I am closing this topic. Thank you!
