Hi
I have just upgraded Nagios core on Centos 7.2 to Version 4.3.4 from 4.0.8. After to upgrade I am getting the following error when running check_ldap
./check_ldap: relocation error: ./check_ldap: symbol X509_check_host, version libcrypto.so.10 not defined in file libcrypto.so.10 with link time reference
Error in GUI is for check_http is
(Return code of 127 is out of bounds - plugin may be missing : (No output on stdout) stderr: /usr/lib64/nagios/plugins/check_http: relocation error: /usr/lib64/nagios/plugins/check_http: symbol X509_check_host, version libcrypto.so.10 not defined in file libcrypto.so.10 with link time reference))
check_ldap/check_http error after upgrade
Re: check_ldap/check_http error after upgrade
Do you have openssl installed?
This would have to have happened outside of the scope of a nagios upgrade.
yum install opensslRe: check_ldap/check_http error after upgrade
Yes openssl is installed
rpm -q openssl
openssl-1.0.1e-51.el7_2.5.x86_64Re: check_ldap/check_http error after upgrade
Hi
An update to openssl has fixed the issue
Excellent! Glad to hear it is resolved!dcolhoun wrote:Hi
Locking
