With an Oracle Query monitor running in Nagios XI, Cylance PROTECT software running on our database server is blocking whatever script Nagios XI is trying to run. I asked our support team to set up an exception, but they came back asking what folder the script is in. Please advise.
And regarding this same monitor, Nagios XI returns:
CRITICAL - cannot connect to HOSTNAME:1521/dbname. install_driver(Oracle) failed: Can't load '/usr/local/lib64/perl5/auto/DBD/Oracle/Oracle.so' for module DBD::Oracle: libocci.so.12.1: cannot open shared object file: No such file or directory at /usr/lib
I can't find libocci.so.12.1. Where is the Linux 'locate' command?
Thanks.
Steve
Cylance PROTECT blocking Nagios XI Oracle Query monitor
Re: Cylance PROTECT blocking Nagios XI Oracle Query monitor
I don't believe these correlate to the same check
The powershell one is likely being called by an agent where the other looks like a direct oracle check
I agree with @scottwilkerson, it looks like the errors are unrelated.
For the Oracle errors on the Nagios server, take a look at this guide for some step in troubleshooting the plugin that you are running on the Nagios server.
