Upgrade from 5.2.7 to 5.5.0 failed
Re: Upgrade from 5.2.7 to 5.5.0 failed
Its still failing.
Please see the attached output.
Can you try to find out what is the root cause of this? Unless we don't work out what is causing this issue, I don't think we'll be able to resolve it.
There is an error in there blocking writing of at least one file
Please post the output of the following
<span class='urgent'>Cannot open/overwrite service configuration files (check the permissions)!</span><br>
ls -la /usr/local/nagios/etc/services
[root@nagios ~]# ls -la /usr/local/nagios/etc/services
total 32
drwxrwxr-x 2 apache nagios 20480 Aug 7 10:09 .
drwxrwxr-x 8 apache nagios 4096 Jul 23 10:08 ..
-rw-rw-r-- 1 apache nagios 1109 Aug 7 10:08 check_mysql_slavestatus.cfg
-rw-rw-r-- 1 root root 1481 Aug 7 10:09 devops_nrpe_httpd.cfg
I changed the permissions for devops_nrpe_httpd.cfg file to:
-rw-rw-r-- 1 apache nagios 1481 Aug 7 10:09 devops_nrpe_httpd.cfg
Then tried "Verify Files" and I was still getting an error so I "Deleted Files" and "Write Files" again. Now I only have 1 file in Services
[root@nagios services]# ls -al /usr/local/nagios/etc/services
total 28
drwxrwxr-x 2 apache nagios 20480 Aug 8 09:36 .
-rw-rw-r-- 1 apache apache 1109 Aug 8 09:36 check_mysql_slavestatus.cfg
total 32
total 28
Did you get an error in the screen?pdd-devops wrote:so I "Deleted Files" and "Write Files" again.
Yes I did, here's the error:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/check_mysql_slavestatus.cfg', starting on line 16)
Nagios Core 4.4.1
Last Modified: 2018-06-25
License: GPL
Reading configuration data...
Read main config file okay...
This service has both hosts and description. I've attached a screenshot for you.
Nagios Core 4.4.1
License: GPL
Can you go to CCM -> Services
Select the check_mysql_slavestatus template
Click the "view config icon" to the right of the service and post the output here
# Services configuration file
# Created by: Nagios CCM 2.7.0
# Date: 2018-08-13 10:00:08
# Version: Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
service_description check_mysql_slavestatus
check_command check_mysql_slavestatus.sh!!nagios!xxxxxxxx!!!!!
max_check_attempts 5
check_interval 5
retry_interval 1
check_period 24x7
notification_period 24x7
register 1
# END OF FILE
check_interval 5
retry_interval 1
check_period 24x7
register 1
# END OF FILE
So it doesn't think there are any hosts assigned, maybe the 4 that were assigned are now inactive?
Select the check_mysql_slavestatus config
Edit
Click Manage hosts
Are the correct hosts selected? Are they all active hosts?
Edit
Click Manage hosts
Yes all 4 hosts are active!
As I've said before all of these services are working in Nagios XI 5.2.7. We're seeing these issues only once Nagios XI is upgraded to 5.5.1.
I'm not sure why they aren't showing in the config, so here is what I propose we do
CCM -> Services
Edit check_mysql_slavestatus
Click Manage hosts
remove the 4 hosts form the right and re-add them from the left
Click Close
Save
Apply Configuration
CCM -> Services
Click Manage hosts
Click Close
Save
Apply Configuration
