When viewing the dashboard is there a way to show more than 250 messages.
It seems like it is a small sample, I need more like 1000 messages.
Dashboard viewing all events
Re: Dashboard viewing all events
If you click the gear to the right of "Export as CSV" then the Paging tab you can select whatever size you would like
Exports only 250 events. Same as what is being displayed.
Never mind I figured it out.
Thanks.
Thanks.
closingfasanchez wrote:Never mind I figured it out.
Thanks.
