Cannot access Nagios web interface remotely
sa2057
Post by sa2057 »
Hello all,
I'm new to Nagios. Hope some one could provide advice to me.
I've installed Nagios on Cent OS vm . Everything went well as I can monitor windows machines etc. The only problem is I cant access the web interface from my pc or any other pc apart from Nagios server.
Is there any which I need to edit on httpd.conf
SA
jsmurphy
Re: Cannot access Nagios web interface remotely
Post by jsmurphy »
is iptables running on the server and have you allowed other hosts access? Run the command iptables --list to check.
sa2057
Post by sa2057 »
Thanks for the response . Below is the output... when I run iptables --list
iptables --list
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh
REJECT all -- anywhere anywhere reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
sa2057
Post by sa2057 »
It works now.
I have enabled the http on the local firewall.
SA
jsmurphy
Post by jsmurphy »
You're welcome :)
