Acknowldgement is not working
Re: Acknowldgement is not working
Is the other functionality working properly now? I'm wondering if there was some corruption in the retention.dat.
Thanks ssax,
yes, system load has drastically come down,
web gui is working fine on applying settings and making changes.
I have noticed that this new retention.dat is just 5.5M where as the file I deleted was around 600M in size. (should have copied it before rm -rf)
There was a bug in the earlier version that actually made many duplicates of all of the comments that have ever been made on the system which is what was ballooning the retention.dat.absarcompass wrote:Thanks ssax,
Hi Guys,
after deletion of retention file, I used the system for couple of weeks before updating to version 5.5.6.
yesterday I updated the version to 5.5.6 and have noticed since then the load average has increased and have not settled down after almost around 24 hours.
the retention file size has not increased though but it takes couple of minutes to get the service check back on GUI after a nagios service restart.
has this retention file issue fixed in this version? and system load issue is related?
Please PM a fresh copy of your profile so that we can see what's consuming the load.
Thank you
Thank you
Thanks ssax,
have PMd you the system profile
Please PM me your /usr/local/nagios/etc/nagios.cfg and your /usr/local/nagios/etc/ndo2db.cfg again, the one from the profile is still showing the 2014 date so I want to make sure your debug log settings as back to normal.
Hi ssax,
have PMd you the files
thanks alot
thanks alot
The files are proper.
Did the load level off or is it still high? From your profile it looks like it was sending a few scheduled reports which could cause it to spike.
What is the output of this command?
ls -lh /usr/local/nagiosxi/var
thanks ssax,
Yes,load is not weirdly high now, but not like how it was before.
below is the output
below is the output
[root@nagiosxi ~]# ls -lh /usr/local/nagiosxi/var
total 36M
drwxrwxr-x 2 nagios nagios 4.0K Aug 2 14:53 certs
-rw-r--r-- 1 nagios nagios 3.5M Nov 15 09:30 cleaner.log
-rw-r--r-- 1 nagios nagios 1.4K Sep 24 2017 cleaner.log-20170924
-rw-r--r-- 1 nagios nagios 1.4K Oct 2 2017 cleaner.log-20171002
-rw-r--r-- 1 nagios nagios 1.4K Oct 9 2017 cleaner.log-20171009
-rw-r--r-- 1 nagios nagios 1.4K Oct 17 2017 cleaner.log-20171017
-rw-r--r-- 1 nagios nagios 24K Nov 7 03:49 cleaner.log-20181107.gz
-rw-r--r-- 1 nagios nagios 2.4M Nov 15 09:30 cmdsubsys.log
-rw-r--r-- 1 nagios nagios 82 Oct 2 2017 cmdsubsys.log-20171002
-rw-r--r-- 1 nagios nagios 82 Oct 8 2017 cmdsubsys.log-20171008
-rw-r--r-- 1 nagios nagios 82 Oct 15 2017 cmdsubsys.log-20171015
-rw-r--r-- 1 nagios nagios 81 Oct 23 2017 cmdsubsys.log-20171023
-rw-r--r-- 1 nagios nagios 89K Oct 28 02:53 cmdsubsys.log-20181028.gz
drwsrwsr-x 3 apache nagios 4.0K Nov 9 11:46 components
-rw-r--r-- 1 nagios nagios 7 Nov 15 09:30 corelog.data
-rw-r--r-- 1 nagios nagios 0 Nov 15 09:30 corelog.diff
-rwxrwxr-x 1 nagios nagios 223 Nov 15 09:16 corelog.newobjects
-rw-r--r-- 1 nagios nagios 4.6M Nov 15 09:30 dbmaint.log
-rw-r--r-- 1 nagios nagios 2.7K Oct 1 2017 dbmaint.log-20171001
-rw-r--r-- 1 nagios nagios 2.7K Oct 8 2017 dbmaint.log-20171008
-rw-r--r-- 1 nagios nagios 2.7K Oct 15 2017 dbmaint.log-20171015
-rw-r--r-- 1 nagios nagios 2.7K Oct 22 2017 dbmaint.log-20171022
-rw-r--r-- 1 nagios nagios 254K Nov 11 02:53 dbmaint.log-20181111.gz
-rw-r--r-- 1 nagios nagios 1.5M Nov 15 09:30 deadpool.log
-rw-r--r-- 1 nagios nagios 75 Oct 3 2017 deadpool.log-20171003
-rw-r--r-- 1 nagios nagios 75 Oct 10 2017 deadpool.log-20171010
-rw-r--r-- 1 nagios nagios 75 Oct 16 2017 deadpool.log-20171016
-rw-r--r-- 1 nagios nagios 75 Oct 23 2017 deadpool.log-20171023
-rw-r--r-- 1 nagios nagios 23K Nov 1 02:53 deadpool.log-20181101.gz
-rw-r--r-- 1 nagios users 0 Nov 15 09:30 event_handler.lock
-rw-r--r-- 1 nagios nagios 3.9M Nov 15 09:30 event_handler.log
-rw-r--r-- 1 nagios nagios 2.2K Oct 2 2017 event_handler.log-20171002
-rw-r--r-- 1 nagios nagios 2.2K Oct 8 2017 event_handler.log-20171008
-rw-r--r-- 1 nagios nagios 2.3K Oct 15 2017 event_handler.log-20171015
-rw-r--r-- 1 nagios nagios 8.2K Oct 23 2017 event_handler.log-20171023
-rw-r--r-- 1 nagios nagios 376K Nov 13 02:53 event_handler.log-20181113.gz
-rw-r--r-- 1 nagios nagios 869K Nov 15 09:30 eventman.log
-rw-r--r-- 1 nagios nagios 40 Oct 1 2017 eventman.log-20171001
-rw-r--r-- 1 nagios nagios 8.5K Oct 9 2017 eventman.log-20171009
-rw-r--r-- 1 nagios nagios 2.3K Oct 15 2017 eventman.log-20171015
-rw-r--r-- 1 nagios nagios 8.2K Oct 23 2017 eventman.log-20171023
-rw-r--r-- 1 nagios nagios 284K Nov 15 02:53 eventman.log-20181115.gz
-rw-r--r-- 1 nagios nagios 3.2M Nov 15 09:30 feedproc.log
-rw-r--r-- 1 nagios nagios 25 Oct 3 2017 feedproc.log-20171003
-rw-r--r-- 1 nagios nagios 25 Oct 10 2017 feedproc.log-20171010
-rw-r--r-- 1 nagios nagios 25 Oct 17 2017 feedproc.log-20171017
-rw-r--r-- 1 nagios nagios 25 Oct 23 2017 feedproc.log-20171023
-rw-r--r-- 1 nagios nagios 52K Aug 14 02:53 feedproc.log-20180814.gz
drwxrwxr-x 2 nagios nagios 4.0K Aug 2 14:53 keys
-rw-r--r-- 1 nagios nagios 962 Oct 24 12:10 load_url.log
-rw-r--r-- 1 nagios nagios 1.7K Oct 1 2017 load_url.log-20171001
-rw-r--r-- 1 nagios nagios 1.7K Oct 8 2017 load_url.log-20171008
-rw-r--r-- 1 nagios nagios 1.7K Oct 15 2017 load_url.log-20171015
-rw-r--r-- 1 nagios nagios 1.7K Oct 22 2017 load_url.log-20171022
-rw-r--r-- 1 nagios nagios 3.0M Nov 14 13:14 nom.log
-rw-r--r-- 1 nagios nagios 23K Oct 24 13:36 nom.log-20181024.gz
-rw-rw-rw- 1 nagios nagios 0 Aug 2 14:54 NXTI_Write_Test
-rw-r--r-- 1 nagios nagios 2.3M Nov 15 09:30 perfdataproc.log
-rw-r--r-- 1 nagios nagios 81 Oct 1 2017 perfdataproc.log-20171001
-rw-r--r-- 1 nagios nagios 81 Oct 8 2017 perfdataproc.log-20171008
-rw-r--r-- 1 nagios nagios 81 Oct 15 2017 perfdataproc.log-20171015
-rw-r--r-- 1 nagios nagios 81 Oct 22 2017 perfdataproc.log-20171022
-rw-r--r-- 1 nagios nagios 243K Oct 26 02:53 perfdataproc.log-20181026.gz
-rw-r--r-- 1 nagios nagios 4.2M Nov 15 09:01 recurringdowntime.log
-rw-r--r-- 1 nagios nagios 141K Oct 1 2017 recurringdowntime.log-20171001
-rw-r--r-- 1 nagios nagios 140K Oct 8 2017 recurringdowntime.log-20171008
-rw-r--r-- 1 nagios nagios 136K Oct 15 2017 recurringdowntime.log-20171015
-rw-r--r-- 1 nagios nagios 137K Oct 22 2017 recurringdowntime.log-20171022
-rw-r--r-- 1 nagios nagios 657K Aug 1 02:53 recurringdowntime.log-20180801.gz
-rw-r--r-- 1 nagios nagios 122K Oct 24 12:37 reportengine.log
drwxr-xr-x 2 nagios nagios 4.0K Nov 13 09:26 subsys
-rw-r--r-- 1 nagios nagios 3.3M Nov 15 09:30 sysstat.log
-rw-r--r-- 1 nagios nagios 8.1K Sep 24 2017 sysstat.log-20170924
-rw-r--r-- 1 nagios nagios 8.1K Oct 2 2017 sysstat.log-20171002
-rw-r--r-- 1 nagios nagios 8.1K Oct 9 2017 sysstat.log-20171009
-rw-r--r-- 1 nagios nagios 8.1K Oct 19 2017 sysstat.log-20171019
-rw-r--r-- 1 nagios nagios 542K Nov 15 02:53 sysstat.log-20181115.gz
drwxr-xr-x 2 apache nagios 4.0K Nov 8 13:09 upgrades
-rw-r--r-- 1 nagios nagios 6.5K Nov 8 13:08 xi-sys.cfg
-rw-r--r-- 1 nagios nagios 37 Mar 28 2017 xi-uuid
-rw-r--r-- 1 nagios nagios 196 Nov 8 13:08 xiversion
[root@nagiosxi ~]#
