I've noticed /usr/local/nagiosxi/tmp contains 1585+ files, some of which are dated over a year old. Generally the files are less than 1M, but one exceeds 2GB in size.
Doesn't Nagios XI automatically clean this up, or is it safe to remove these files manually?
Hello, @TBT. Generally, these are temporary files left by various upgrade scripts and components and safe to be removed. Can you let me know the name of the file that takes up 2gb?
npolovenko wrote:Hello, @TBT. Generally, these are temporary files left by various upgrade scripts and components and safe to be removed. Can you let me know the name of the file that takes up 2gb?
-rwxrwxr-- 1 nagios nagios 2.2G Jan 19 2017 ./snmpwalk--<IP-address>
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
