Availability report .csv file only showing services
emartine
Post by emartine »
When I run an Availability Report and send via email I am able to see the PDF version for host and services and a graph without issue. However, when I run the Availability Report and send via email as a .csv file and tell it to combine both I only see the Services and I do not see labels on the columns nor hosts. Should I see labels as well as hosts and then services or am I misinterpreting what combined means here?
These are the options:
CSV (Combined) <--- I am using this one.
CSV (Host data only)
CSV (Service data only)
Re: Availability report .csv file only showing services
I was able to recreate the issue and filed an internal bug report (task_id=13573). Thank you for reporting this!
