Warnings in preflight checks
nms
Post by nms »
I am planning for an upgrade from version 5.4.13 to 5.5.3. I ran the preflight check to see that everything is fine prior to starting the upgrade.
all is ok except for a number of warnings:
    Checked 308 hosts.
        Checked 43 host groups.
        Checked 91 service groups.
        Checked 72 contacts.
        Checked 7 contact groups.
        Checked 270 commands.
        Checked 77 time periods.
        Checked 0 host escalations.
        Checked 308 hosts
        Checked 0 host dependencies
        Checked 77 timeperiods
Checking misc settings...
Total Warnings: 1021
Total Errors:   0
Basically, the 1021 warning are of two categories:
1. Duplicate definition found in service
2. No default contact or contact groups defined
For 2, I don't think it should be worrying and if creates an issue for the upgrade (i think!). I'm more worried about the duplicate definition. Here's some example from the preflight:
eading configuration data...
   Read main config file okay...
Warning: Duplicate definition found for service '100_T-ipops-CIS014_HardwareHealth' on host 'mt1-sha-itp01-p_o-mt1itp01
' (config file '/usr/local/nagios/etc/services/mt1-sha-itp01-p_o-mt1itp01.cfg', starting on line 81)
Warning: Duplicate definition found for service '200_T-itinfra-ORA003-OracleInvalidObjects' on host 'abj-oci-sms01-p_v-
vmaas' (config file '/usr/local/nagios/etc/services/bru-ofc-das01-p_v-ofc.cfg', starting on line 604)
Warning: Duplicate definition found for service '300_S-SMSE014-TimeElapsedSinceLastIncomingSMS' on host 'abj-oci-msd01-
p_v-vmaas' (config file '/usr/local/nagios/etc/services/abj-oci-sms02-p_v-vmaas.cfg', starting on line 257)
Let's take the first one for example.
if I look at the "/usr/local/nagios/etc/services/mt1-sha-itp01-p_o-mt1itp01.cfg" I don't see any duplicate entry for "100_T-ipops-CIS014_HardwareHealth" service, nor is the hostname removed before. I checked quite a lot of them and it's the same behavior, there is no duplicate entry in the file at all.
cfg file starting from line 81:
        host_name                       mt1-sha-itp01-p_o-mt1itp01
        service_description             100_T-ipops-CIS014_HardwareHealth
        use                             xiwizard_switch_ping_service
        check_command                   Aspider-NGI01_ssh!0!0!mt1-sha-itp01-p_o-mt1itp01!!!!/home/nagios/bin/nagios_T-CIS014-HardwareHealth.sh!10.192.254.3
        max_check_attempts              2
        check_interval                  60
        retry_interval                  1
        check_period                    xi_timeperiod_24x7
        notification_interval           60
        notification_period             xi_timeperiod_24x7
        contact_groups                  NOC
        _xiwizard                       switch
        register                        1
        service_description             100_T-ipops-CIS015_Interface Status
        check_command                   Aspider-NGI01_ssh!0!0!mt1-sha-itp01-p_o-mt1itp01!none!!!/home/nagios/bin/nagios_T-CIS009-InterfaceStatus.sh!am1-nms-nmsgw-p_v-nms
        check_interval                  1
        retry_interval                  1
        contact_groups                  NOC
        _xiwizard                       switch
        register                        1
Does this provide an issue for the upgrade after all? Secondly, how can I solve this?
Thanks!
Re: Warnings in preflight checks
what you really want to do is see what all configuration files have that in them
grep 100_T-ipops-CIS014_HardwareHealth -R /usr/local/nagios/etc
It is very commonly caused if you have a hostgroup assigned to a service somewhere and also have a different config that has a host assigned to the same service_description.
nms
Post by nms »
/usr/local/nagios/etc/services/tm1-sim-rtr02-p_r-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-sw01-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/tm1-sim-itp02-p_o-tm1itp02.cfg:  service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/mt1-sha-sw01-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am3-sha-sw02-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/mt1-sha-sw02-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-ssw01-p_s-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/tm1-sim-sw01-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-sw05-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/tm1-sim-sw02-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/tm1-sim-rtr01-p_r-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-swt01-p_s-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-swt02-p_s-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-rtr03-p_r-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-sw06-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-sw02-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-bsw02-p_s-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/mt1-sha-itp01-p_o-mt1itp01.cfg:  service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-bsw01-p_s-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/tm1-sim-itp01-p_o-tm1itp01.cfg:  service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/mt1-sha-itp02-p_o-mt1itp02.cfg:  service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-rtr04-p_r-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am3-sha-sw01-p_s-ipops.cfg:      service_description             100_T-ipops-CIS014_HardwareHealth
/usr/local/nagios/etc/services/am1-sha-rtr05-p_r-ipops.cfg:     service_description             100_T-ipops-CIS014_HardwareHealth
grep: warning: /usr/local/nagios/etc/etc: recursive directory loop
What's the next step to check in these config files?
I would go to the CCM-> Services
Select tm1-sim-rtr02-p_r-ipops from the template dropdown and click edit on 100_T-ipops-CIS014_HardwareHealth
Check to see of a hostgroup is defined.
Repeat for each, if you find a hostgroup defined, especially oif the same hostgroup is defined on multiple checks, remove the host group on all but 1. It may not be necessary for any if the all the hosts that need this check are all covered by the host definition.
nms
Post by nms »
I've checked all the services in CCM for this particular service. Couldn't find any hostgroups assigned on all of them.
Seems the issue could be something else. What else do you think I can eventually check?
Rgds,
If you could PM me your profile.zip from Admin -> System profile I can take a look to see if I can find the issue
nms
Post by nms »
Thank you.
Sent you the profile via pm.
ssax
Dreams In Code
Post by ssax »
swilkerson is out of the office today, you can either wait until Monday for a response or PM me a copy of your profile.
Thank you
looking over the configs you don't have duplicates of these any longer but do have one weird item, and that is a recursive symlink that should eb deleted.
rm -f /usr/local/nagios/etc/etc
I also did find that the host is specified abj-oci-msd01-p_v-vmaas for the service 300_S-SMSE014-TimeElapsedSinceLastIncomingSMS in all these templates:
abj-oci-msd02-p_v-vmaas
abj-oci-msd03-p_v-vmaas
abj-oci-sms01-p_v-vmaas
abj-oci-sms03-p_v-vmaas
all but 1 should be removed. Also, ant-oma-zmsd1-p_v-vmaas & ant-oma-zmsd1-p_v-vmaas contain the same host as each other for this service.
nms
Post by nms »
Thanks for the info. I have deleted the symbolic link and amened the hosts for that service.
I am sending the profile once again via pm. Can you kindly confirm that all is ok and I can go ahead with the upgrade?
Rgds,
