Error: Could not find any host matching
jeffersjw
Post by jeffersjw »
I am getting the following error when trying to apply my config:
Error: Could not find any host matching 'drexchvm01.corp.globetax.com' (config file '/usr/local/nagios/etc/services/drexch02.corp.globetax.com.cfg', starting on line 93)
Error: Could not expand hostgroups and/or hosts specified in service (config file '/usr/local/nagios/etc/services/drexch02.corp.globetax.com.cfg', starting on line 93)
I tried following the steps in https://support.nagios.com/forum/viewto ... =7&t=44126 but it did not resolve the issue.
Also, I have none idea what is being referred to in line 93 as these .cfg files do not contain that many.
Any assistance greatly appreciated!
syang
Re: Error: Could not find any host matching
Post by syang »
You need to correct the object definition error that nagios is complaining about. Try these two possible solutions:
1. Add a host object called 'drexchvm01.corp.globetax.com'
2. Remove 'drexchvm01.corp.globetax.com' from the service definition
After making the change(s), what is the output when you enter this command in the CLI?
If the problem persists, could you include your host/service definitions onto this post?
jeffersjw
Post by jeffersjw »
There were no services bound to it as I had removed them already but I had added and removed the host many times. SHould I add the host bind a service then remove it?
Output is as follows and am still having the issue:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'HTTP' on host 'www.globetax.com' (config file '/usr/local/nagios/etc/services/www.globetax.com.cfg', starting on line 57)
Checking objects...
Checked 1247 services.
Checked 199 hosts.
Checked 27 host groups.
Checked 22 service groups.
Checked 20 contacts.
Checked 2 contact groups.
Checked 126 commands.
Checked 26 time periods.
Checked 0 host escalations.
Checked 199 hosts
Checked 0 host dependencies
Checked 26 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
You have mail in /var/spool/mail/root
syang
Post by syang »
There may something wrong with your database. Before repairing it, be sure to make a backup of your files. You can follow the instructions here: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
After the backup is done, repair the database with this script as root user:
/usr/local/nagiosxi/scripts/repair_databases.sh
Then sign into the terminal as the Nagios User and run this script and show us the output:
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
What version of MYSQL are you running?
To get that, run this as root.
mysql -V
Has the MYSQL database been offloaded to a remote server?
Were there any updates done to the server?
Can you run the following and post the output to the ticket?
echo 'show global status;' |mysql -t -u root -pnagiosxi
It looks like the objects in the Core Config Manager are not in sync with the running config and that is causing the error..
To fix that, login to the XI GUI and go to the Core Config Manager
Under "Tools", click "Write Config Files" or if you are running a newer versions of XI, The menu is called "Config File Management"
Click the click the "Write" button, then the "Delete" button then click the "Write" button and then the "Verify" button
If you get any errors, resolve them and click on the "Delete" button, "Write", "Verify" until all of the errors are resolved.
Click the Apply Configuration link and click the "Apply Configuration" button after ALL of the errors are resolved.
jeffersjw
Post by jeffersjw »
I get this when running the first commands (DB repair):
REPAIR COMPLETE
Stopping ndo2db: done.
Starting ndo2db: done.
Running configuration check...
Nagios Core 4.2.4
License: GPL
Error: Unexpected token or statement in file '/usr/local/nagios/etc/hosts/tmp_xi_vars.cfg' on line 1.
nagios database repair succeeded
nagiosql database repair succeeded
[root@nagios hosts]# /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=Gts9100' -O nagiosql.login--2018-09-14 10:07:04-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
[ <=> ] 38,097 --.-K/s in 0.02s
2018-09-14 10:07:04 (2.37 MB/s) - “nagiosql.login” saved [38097]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
Another reconfigure process is still running, sleeping...
^C
jeffersjw
Post by jeffersjw »
For the second one I followed the steps and saw no errors but when applying any new config still get the same message.
Here is the output from the SQL commands:
[root@nagios hosts]# mysql -V
mysql  Ver 14.14 Distrib 5.1.73, for redhat-linux-gnu (x86_64) using readline 5.1
[root@nagios hosts]# echo 'show global status;' |mysql -t -u root -pnagiosxi
| Variable_name                     | Value     |
| Aborted_clients                   | 1         |
| Aborted_connects                  | 0         |
| Binlog_cache_disk_use             | 0         |
| Binlog_cache_use                  | 0         |
| Bytes_received                    | 448795540 |
| Bytes_sent                        | 203604390 |
| Com_admin_commands                | 32657     |
| Com_assign_to_keycache            | 0         |
| Com_alter_db                      | 0         |
| Com_alter_db_upgrade              | 0         |
| Com_alter_event                   | 0         |
| Com_alter_function                | 0         |
| Com_alter_procedure               | 0         |
| Com_alter_server                  | 0         |
| Com_alter_table                   | 0         |
| Com_alter_tablespace              | 0         |
| Com_analyze                       | 0         |
| Com_backup_table                  | 0         |
| Com_begin                         | 0         |
| Com_binlog                        | 0         |
| Com_call_procedure                | 0         |
| Com_change_db                     | 35850     |
| Com_change_master                 | 0         |
| Com_check                         | 0         |
| Com_checksum                      | 0         |
| Com_commit                        | 0         |
| Com_create_db                     | 0         |
| Com_create_event                  | 0         |
| Com_create_function               | 0         |
| Com_create_index                  | 0         |
| Com_create_procedure              | 0         |
| Com_create_server                 | 0         |
| Com_create_table                  | 0         |
| Com_create_trigger                | 0         |
| Com_create_udf                    | 0         |
| Com_create_user                   | 0         |
| Com_create_view                   | 0         |
| Com_dealloc_sql                   | 0         |
| Com_delete                        | 1023      |
| Com_delete_multi                  | 0         |
| Com_do                            | 0         |
| Com_drop_db                       | 0         |
| Com_drop_event                    | 0         |
| Com_drop_function                 | 0         |
| Com_drop_index                    | 0         |
| Com_drop_procedure                | 0         |
| Com_drop_server                   | 0         |
| Com_drop_table                    | 0         |
| Com_drop_trigger                  | 0         |
| Com_drop_user                     | 0         |
| Com_drop_view                     | 0         |
| Com_empty_query                   | 0         |
| Com_execute_sql                   | 0         |
| Com_flush                         | 0         |
| Com_grant                         | 0         |
| Com_ha_close                      | 0         |
| Com_ha_open                       | 0         |
| Com_ha_read                       | 0         |
| Com_help                          | 0         |
| Com_insert                        | 239552    |
| Com_insert_select                 | 0         |
| Com_install_plugin                | 0         |
| Com_kill                          | 0         |
| Com_load                          | 0         |
| Com_load_master_data              | 0         |
| Com_load_master_table             | 0         |
| Com_lock_tables                   | 0         |
| Com_optimize                      | 156       |
| Com_preload_keys                  | 0         |
| Com_prepare_sql                   | 0         |
| Com_purge                         | 0         |
| Com_purge_before_date             | 0         |
| Com_release_savepoint             | 0         |
| Com_rename_table                  | 0         |
| Com_rename_user                   | 0         |
| Com_repair                        | 0         |
| Com_replace                       | 115       |
| Com_replace_select                | 0         |
| Com_reset                         | 0         |
| Com_restore_table                 | 0         |
| Com_revoke                        | 0         |
| Com_revoke_all                    | 0         |
| Com_rollback                      | 0         |
| Com_rollback_to_savepoint         | 0         |
| Com_savepoint                     | 0         |
| Com_select                        | 139583    |
| Com_set_option                    | 17960     |
| Com_show_authors                  | 0         |
| Com_show_binlog_events            | 0         |
| Com_show_binlogs                  | 0         |
| Com_show_charsets                 | 0         |
| Com_show_collations               | 0         |
| Com_show_column_types             | 0         |
| Com_show_contributors             | 0         |
| Com_show_create_db                | 0         |
| Com_show_create_event             | 0         |
| Com_show_create_func              | 0         |
| Com_show_create_proc              | 0         |
| Com_show_create_table             | 0         |
| Com_show_create_trigger           | 0         |
| Com_show_databases                | 0         |
| Com_show_engine_logs              | 0         |
| Com_show_engine_mutex             | 0         |
| Com_show_engine_status            | 0         |
| Com_show_events                   | 0         |
| Com_show_errors                   | 0         |
| Com_show_fields                   | 0         |
| Com_show_function_status          | 0         |
| Com_show_grants                   | 0         |
| Com_show_keys                     | 0         |
| Com_show_master_status            | 0         |
| Com_show_new_master               | 0         |
| Com_show_open_tables              | 0         |
| Com_show_plugins                  | 0         |
| Com_show_privileges               | 0         |
| Com_show_procedure_status         | 0         |
| Com_show_processlist              | 0         |
| Com_show_profile                  | 0         |
| Com_show_profiles                 | 0         |
| Com_show_slave_hosts              | 0         |
| Com_show_slave_status             | 0         |
| Com_show_status                   | 1         |
| Com_show_storage_engines          | 0         |
| Com_show_table_status             | 0         |
| Com_show_tables                   | 0         |
| Com_show_triggers                 | 0         |
| Com_show_variables                | 0         |
| Com_show_warnings                 | 0         |
| Com_slave_start                   | 0         |
| Com_slave_stop                    | 0         |
| Com_stmt_close                    | 0         |
| Com_stmt_execute                  | 0         |
| Com_stmt_fetch                    | 0         |
| Com_stmt_prepare                  | 0         |
| Com_stmt_reprepare                | 0         |
| Com_stmt_reset                    | 0         |
| Com_stmt_send_long_data           | 0         |
| Com_truncate                      | 23        |
| Com_uninstall_plugin              | 0         |
| Com_unlock_tables                 | 0         |
| Com_update                        | 233       |
| Com_update_multi                  | 0         |
| Com_xa_commit                     | 0         |
| Com_xa_end                        | 0         |
| Com_xa_prepare                    | 0         |
| Com_xa_recover                    | 0         |
| Com_xa_rollback                   | 0         |
| Com_xa_start                      | 0         |
| Compression                       | OFF       |
| Connections                       | 3229      |
| Created_tmp_disk_tables           | 6         |
| Created_tmp_files                 | 15        |
| Created_tmp_tables                | 4558      |
| Delayed_errors                    | 0         |
| Delayed_insert_threads            | 0         |
| Delayed_writes                    | 0         |
| Flush_commands                    | 1         |
| Handler_commit                    | 0         |
| Handler_delete                    | 2352      |
| Handler_discover                  | 0         |
| Handler_prepare                   | 0         |
| Handler_read_first                | 79265     |
| Handler_read_key                  | 3377650   |
| Handler_read_next                 | 2635749   |
| Handler_read_prev                 | 0         |
| Handler_read_rnd                  | 283703    |
| Handler_read_rnd_next             | 4982407   |
| Handler_rollback                  | 0         |
| Handler_savepoint                 | 0         |
| Handler_savepoint_rollback        | 0         |
| Handler_update                    | 163304    |
| Handler_write                     | 770857    |
| Innodb_buffer_pool_pages_data     | 19        |
| Innodb_buffer_pool_pages_dirty    | 0         |
| Innodb_buffer_pool_pages_flushed  | 0         |
| Innodb_buffer_pool_pages_free     | 493       |
| Innodb_buffer_pool_pages_misc     | 0         |
| Innodb_buffer_pool_pages_total    | 512       |
| Innodb_buffer_pool_read_ahead_rnd | 1         |
| Innodb_buffer_pool_read_ahead_seq | 0         |
| Innodb_buffer_pool_read_requests  | 77        |
| Innodb_buffer_pool_reads          | 12        |
| Innodb_buffer_pool_wait_free      | 0         |
| Innodb_buffer_pool_write_requests | 0         |
| Innodb_data_fsyncs                | 3         |
| Innodb_data_pending_fsyncs        | 0         |
| Innodb_data_pending_reads         | 0         |
| Innodb_data_pending_writes        | 0         |
| Innodb_data_read                  | 2494464   |
| Innodb_data_reads                 | 25        |
| Innodb_data_writes                | 3         |
| Innodb_data_written               | 1536      |
| Innodb_dblwr_pages_written        | 0         |
| Innodb_dblwr_writes               | 0         |
| Innodb_log_waits                  | 0         |
| Innodb_log_write_requests         | 0         |
| Innodb_log_writes                 | 1         |
| Innodb_os_log_fsyncs              | 3         |
| Innodb_os_log_pending_fsyncs      | 0         |
| Innodb_os_log_pending_writes      | 0         |
| Innodb_os_log_written             | 512       |
| Innodb_page_size                  | 16384     |
| Innodb_pages_created              | 0         |
| Innodb_pages_read                 | 19        |
| Innodb_pages_written              | 0         |
| Innodb_row_lock_current_waits     | 0         |
| Innodb_row_lock_time              | 0         |
| Innodb_row_lock_time_avg          | 0         |
| Innodb_row_lock_time_max          | 0         |
| Innodb_row_lock_waits             | 0         |
| Innodb_rows_deleted               | 0         |
| Innodb_rows_inserted              | 0         |
| Innodb_rows_read                  | 0         |
| Innodb_rows_updated               | 0         |
| Key_blocks_not_flushed            | 0         |
| Key_blocks_unused                 | 5415      |
| Key_blocks_used                   | 6694      |
| Key_read_requests                 | 10063245  |
| Key_reads                         | 525108    |
| Key_write_requests                | 752350    |
| Key_writes                        | 482915    |
| Last_query_cost                   | 0.000000  |
| Max_used_connections              | 62        |
| Not_flushed_delayed_rows          | 0         |
| Open_files                        | 98        |
| Open_streams                      | 0         |
| Open_table_definitions            | 89        |
| Open_tables                       | 56        |
| Opened_files                      | 1379      |
| Opened_table_definitions          | 291       |
| Opened_tables                     | 388       |
| Prepared_stmt_count               | 0         |
| Qcache_free_blocks                | 0         |
| Qcache_free_memory                | 0         |
| Qcache_hits                       | 0         |
| Qcache_inserts                    | 0         |
| Qcache_lowmem_prunes              | 0         |
| Qcache_not_cached                 | 0         |
| Qcache_queries_in_cache           | 0         |
| Qcache_total_blocks               | 0         |
| Queries                           | 470338    |
| Questions                         | 470338    |
| Rpl_status                        | NULL      |
| Select_full_join                  | 0         |
| Select_full_range_join            | 0         |
| Select_range                      | 2571      |
| Select_range_check                | 0         |
| Select_scan                       | 5552      |
| Slave_open_temp_tables            | 0         |
| Slave_retried_transactions        | 0         |
| Slave_running                     | OFF       |
| Slow_launch_threads               | 0         |
| Slow_queries                      | 0         |
| Sort_merge_passes                 | 0         |
| Sort_range                        | 1119      |
| Sort_rows                         | 53985     |
| Sort_scan                         | 1732      |
| Ssl_accept_renegotiates           | 0         |
| Ssl_accepts                       | 0         |
| Ssl_callback_cache_hits           | 0         |
| Ssl_cipher                        |           |
| Ssl_cipher_list                   |           |
| Ssl_client_connects               | 0         |
| Ssl_connect_renegotiates          | 0         |
| Ssl_ctx_verify_depth              | 0         |
| Ssl_ctx_verify_mode               | 0         |
| Ssl_default_timeout               | 0         |
| Ssl_finished_accepts              | 0         |
| Ssl_finished_connects             | 0         |
| Ssl_session_cache_hits            | 0         |
| Ssl_session_cache_misses          | 0         |
| Ssl_session_cache_mode            | NONE      |
| Ssl_session_cache_overflows       | 0         |
| Ssl_session_cache_size            | 0         |
| Ssl_session_cache_timeouts        | 0         |
| Ssl_sessions_reused               | 0         |
| Ssl_used_session_cache_entries    | 0         |
| Ssl_verify_depth                  | 0         |
| Ssl_verify_mode                   | 0         |
| Ssl_version                       |           |
| Table_locks_immediate             | 543059    |
| Table_locks_waited                | 362       |
| Tc_log_max_pages_used             | 0         |
| Tc_log_page_size                  | 0         |
| Tc_log_page_waits                 | 0         |
| Threads_cached                    | 0         |
| Threads_connected                 | 41        |
| Threads_created                   | 3228      |
| Threads_running                   | 1         |
| Uptime                            | 7032      |
| Uptime_since_flush_status         | 7032      |
npolovenko
Post by npolovenko »
@jeffersjw, I would like to schedule a remote session and take a closer look at your config files. Please open a support ticket here so we can arrange a remote session.
https://support.nagios.com/tickets
jeffersjw
Post by jeffersjw »
Opened. I am available for the next hour.
npolovenko
@jeffersjw, Great. I responded in the ticket. I will be closing this thread so we can focus our efforts.
