SSL_ERR 5 Error -Could not complete SSL handshake with
valkeyr
Post by valkeyr »
After upgrading Nagios XI 5.4.13 --> Nagios XI 5.5.3 NRPE checks stopped working on ALL hosts(they were working fine on version 5.4.13).
NSCLIENT.ini output;
[/modules]
CheckExternalScripts = 1
CheckHelpers = 1
CheckEventLog = 1
CheckNSCP = 1
CheckDisk = 1
CheckSystem = 1
NRPEServer = 1
[/settings/eventlog]
buffer size = 131072
debug = false
lookup names = true
syntax =
[/settings/external scripts]
allow arguments = true
allow nasty characters = true
timeout = 60
[/settings/external scripts/wrappings]
bat = scripts\\%SCRIPT% %ARGS%
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
;exe = cmd /c %SCRIPT% %ARGS%
[/settings/external scripts/alias]
;alias_cpu = checkCPU warn=80 crit=90 time=5m time=1m time=30s
;alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; ...skipping lines as we do provide LOT of alias for you...
;alias_updates = check_updates -warning 0 -critical 0
;alias_volumes = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
;alias_volumes_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
check_exchange_queue=cmd /c echo scripts\check_exchange_queue.ps1 $ARG1$ $ARG2$ $ARG3$; exit($lastexitcode) | powershell.exe -noprofile -nologo -command  -
check_complus=cscript.exe //T:30 //NoLogo scripts\check_complus.vbs $ARG1$
check_domain=cscript.exe //T:60 //NoLogo scripts\check_domain.vbs
check_updates=cscript.exe //T:60 //NoLogo scripts\check_windows_updates.vbs
check_pubfolders=cmd /c echo scripts\check_pubfolders.ps1; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_mbxdatabases=cmd /c echo scripts\check_mbxdatabases.ps1; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_lunusage=cmd /c echo scripts\read_lun_file.ps1 $ARG1$; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_snapshots=cmd /c echo scripts\check_snapshots.ps1 $ARG1$ $ARG2$; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_xenapp_sessions=cmd /c echo scripts\xenapp_sessions.ps1 $ARG1$ $ARG2$; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_xenapp_profit=cmd /c echo scripts\xenapp_profit.ps1; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_xenapp_desktop=cmd /c echo scripts\xenapp_desktop.ps1; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_fileshare=cmd /c echo scripts\check_cluster.ps1 $ARG1$; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_terminal_sessions=cmd /c echo scripts\terminal_sessions.ps1; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
check_citrix_licenses=cmd /c echo scripts\citrix_licenses.ps1; exit($lastexitcode) | powershell.exe -noprofile -nologo -command -
;check_updates=check_updates.vbs $ARG1$ $ARG2$
[/paths]
shared-path = C:\Program Files\NSClient++
certificate-path = ${shared-path}\security
[/settings/NRPE/server]
allowed hosts=172.1.1.1 ( DUMMY)
allowed ciphers = ALL:!MD5:@STRENGTH
extended response = 0
port=5666
ssl options=
insecure = true
dh=${certificate-path}/nrpe_dh_512.pem
certificate=${certificate-path}/certificate.pem
certificate format=PEM
Used all the tricks i know. Anyone had the same problem and found a solution?
valkeyr
Re: SSL_ERR 5 Error -Could not complete SSL handshake with
Post by valkeyr »
We were able to reproduce the situation in a test environment. Same issue: before the upgrade everything works fine, after upgrading NRPE checks stopped working.
Included export of Nagios XI System Info (profile):
Nagios XI - System Info
System
Nagios XI version: 5.5.4
XI installed from: source
XI UUID: f050291c-b495-4e76-804f-c5aad8495a4e
Release info: MON02.domain.nl 3.10.0-862.3.3.el7.x86_64 x86_64
CentOS Linux release 7.5.1804 (Core)
Gnome is not installed
Apache Information
PHP Version: 5.4.16
Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36
Server Name: nagios.domain.nl
Server Address: 172.17.1.20
Server Port: 80
Date/Time
PHP Timezone: Europe/Amsterdam
PHP Time: Wed, 26 Sep 2018 11:21:31 +0200
System Time: Wed, 26 Sep 2018 11:21:31 +0200
Nagios XI Data
License ends in:
Install Type: source
Sep 26 11:21:01 MON02.domain.nl sudo[6096]: nagios : TTY=unknown ; PWD=/tmp ; USER=root ; COMMAND=/usr/local/nagiosxi/scripts/manage_services.sh status mysqld
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Sep 26 11:20:28 MON02.domain.nl ndo2db[14908]: Trimming eventhandlers.
CPU Load 15: 0.60
Total Hosts: 3
Total Services: 20
Function get_base_uri() returns: http://nagios.domain.nl/nagiosxi/
Function get_base_url() returns: http://nagios.domain.nl/nagiosxi/
Function get_backend_url(internal_call=false) returns: http://nagios.domain.nl/nagiosxi/includes/components/profile/profile.php
Function get_backend_url(internal_call=true) returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.062 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.070 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.067 ms
--- localhost ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.062/0.066/0.070/0.007 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2018-09-26 11:21:33-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://localhost/nagiosxi/login.php?redirect=/nagiosxi/includes/components/ccm/index.php%3f&noauth=1 [following]
--2018-09-26 11:21:33-- http://localhost/nagiosxi/login.php?redirect=/nagiosxi/includes/components/ccm/index.php%3f&noauth=1
Reusing existing connection to [localhost]:80.
Length: unspecified [text/html]
Saving to: '/usr/local/nagiosxi/tmp/ccm_index.tmp'
0K .......... .......... .... 7.44M=0.003s
2018-09-26 11:21:33 (7.44 MB/s) - '/usr/local/nagiosxi/tmp/ccm_index.tmp' saved [25433]
Network Settings
1: lo:  mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: ens160:  mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:50:56:bb:17:d6 brd ff:ff:ff:ff:ff:ff
    inet 172.17.1.20/20 brd 172.17.15.255 scope global noprefixroute ens160
    inet6 fe80::e763:b87b:bff2:4d23/64 scope link noprefixroute
default via 192.168.1.254 dev ens160 proto static metric 100
172.17.0.0/20 dev ens160 proto kernel scope link src 172.17.1.20 metric 100
Nagios XI Components
actions	2.0.1
alertcloud	1.2.1
alertstream	2.1.0
autodiscovery	2.2.5
backendapiurl	1.0.3
bandwidthreport	1.8.0
bbmap	1.2.0
birdseye	3.2.2
bulkmodifications	2.2.0
capacityplanning	2.3.0
ccm	2.7.0
custom-includes	1.0.4
customlogin	1.0.0
customlogo	1.2.0
deploydashboard	1.3.0
deploynotification	1.3.3
duo	1.0.0
escalationwizard	1.5.0
freevariabletab	1.0.1
globaleventhandler	1.2.2
graphexplorer	2.2.1
helpsystem	2.0.0
highcharts	4.0.1
homepagemod	1.1.8
hypermap	1.2.0
hypermap_replay	1.2.0
isms	1.2.3
latestalerts	1.2.6
ldap_ad_integration	1.1.0
massacknowledge	2.1.14
metrics	1.2.10
minemap	1.2.4
nagiosbpi	2.7.1
nagioscore
nagioscorecfg
nagiosim	2.2.6
nagiosna	1.4.0
nagiosql
nagvis	2.0.0
nocscreen	1.1.2
nrdsconfigmanager	1.6.4
nxti	1.0.1
opscreen	1.8.0
perfdata
pingaction	1.1.1
pnp
profile	1.4.0
proxy	1.1.4
rdp	1.0.3
rename	1.6.0
scheduledbackups	1.2.0
scheduledreporting
similetimeline	1.5.0
snmptrapsender	1.5.5
statusmap	1.0.2
tracerouteaction	1.1.1
usermacros	1.1.0
xicore
Nagios XI Config Wizards
ec2	1.0.0
s3	1.0.0
autodiscovery	1.4.2
bpiwizard	1.1.4
bulkhostimport	2.0.4
digitalocean	1.0.0
google-cloud	1.0.0
linode	1.0.0
microsoft-azure	1.0.0
rackspace	1.0.0
dhcp	1.1.4
dnsquery	1.1.3
docker	1.0.1
domain_expiration	1.1.4
email-delivery	2.0.4
esensors_websensor	1.1.4
exchange	1.3.2
folder_watch	1.0.5
ftpserver	1.5.5
genericnetdevice	1.0.3
ldapserver	1.3.3
linux-server	1.5.5
linux_snmp	1.5.5
macosx	1.3.0
mailserver	1.2.4
mongodb_database	1.1.2
mongodbserver	1.1.2
mountpoint	1.0.2
mssql_database	1.6.2
mssql_query	1.6.4
mssql_server	1.9.1
mysqlquery	1.2.3
mysqlserver	1.3.3
nagioslogserver	1.0.5
nagiostats	1.2.3
nagiosxiserver	1.3.0
ncpa	2.0.1
nna	1.0.4
nrpe	1.5.2
oraclequery	1.3.3
oracleserverspace	1.5.3
oracletablespace	1.5.4
passivecheck	1.2.4
passiveobject	1.1.3
postgresdb	1.5.3
postgresquery	1.2.3
postgresserver	1.3.4
printer	1.1.3
radiusserver	2.0.1
sla	1.3.2
snmp	1.6.0
snmp_trap	1.5.3
snmpwalk	1.3.7
solaris	1.2.5
sshproxy	1.5.7
switch	2.4.0
tcpudpport	1.3.3
tftp	1.0.2
vmware	1.7.1
watchguard	1.4.5
website	1.3.0
website_defacement	1.1.5
websiteurl	1.3.7
webtransaction	1.2.5
windowseventlog	1.3.3
windowsserver	1.6.2
windowsdesktop	1.6.2
windowssnmp	1.5.2
windowswmi	2.1.0
Nagios XI Dashlets
alertcloud
bbmap
capacityplanning
graphexplorer
hypermap
latestalerts
metrics
metricsguage
minemap
xicore_xi_news_feed
xicore_getting_started
xicore_admin_tasks
xicore_eventqueue_chart
xicore_component_status
xicore_server_stats
xicore_monitoring_stats
xicore_monitoring_perf
xicore_monitoring_process
xicore_perfdata_chart
xicore_host_status_summary
xicore_service_status_summary
xicore_comments
xicore_hostgroup_status_overview
xicore_hostgroup_status_grid
xicore_servicegroup_status_overview
xicore_servicegroup_status_grid
xicore_hostgroup_status_summary
xicore_servicegroup_status_summary
xicore_available_updates
xicore_network_outages
xicore_network_outages_summary
xicore_network_health
xicore_host_status_tac_summary
xicore_service_status_tac_summary
xicore_feature_status_tac_summary
availability
custom_dashlet	1.0.5
gauges	1.2.2
googlemapdashlet	1.1.0
internettrafficreport
rss_dashlet	1.1.0
sansrisingports	2.0
sla
worldtimeserver	2.0.0
skang
Post by skang »
Hello Valkeyr,
First, just in case you have not, please try to restart the nsclient service to see if this resolves the issue. You should be able to do this from Services under Administrative Tools.
Could you also include the contents of nsclient.log without sensitive information.
I didn't see the following directive in the nsclient.ini file that you showed us:
use ssl = 1
Do you have this line? If you don't, try adding it under the [/settings/NRPE/server] section, and restart the NSClient++ service to see if this is going to fix your problem.
