npolovenko
Posts: 3457 Joined: Mon May 15, 2017 5:00 pm
Post
by npolovenko » Fri Nov 09, 2018 12:27 pm
@BrunoLosse1 , Lets try the following. Remove the following line from the ini file that I gave you and restart the nsclient service.
allowed ciphers = ALL:!MD5:@STRENGTH
Then run this again:
cd /usr/local/nagios/libexec
./check_nrpe -H <host ip adddress>
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
BrunoLosse1
Posts: 40 Joined: Tue Oct 23, 2018 1:22 pm
Post
by BrunoLosse1 » Fri Nov 09, 2018 12:54 pm
Same error.
Is there any other file I need to edit? Either at the Nagios server or Windows?
npolovenko
Post
by npolovenko » Fri Nov 09, 2018 1:07 pm
@BrunoLosse1 , Possibly. Please run the following command(forcing v2 packets) from the nagios XI server:
./check_nrpe -2 -H <nrpe host ip adddress>
And also this one:
./check_nrpe -n -H <nrpe host ip adddress>
Privacy Policy .
BrunoLosse1
Post
by BrunoLosse1 » Mon Nov 12, 2018 6:21 am
npolovenko wrote: @BrunoLosse1 , Possibly. Please run the following command(forcing v2 packets) from the nagios XI server:
And also this one:
Here's the results:
administrator@GEUL3BNAGPAS01:/usr/local/nagios/libexec$ ./check_nrpe -2 -H 10.63.248.105
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with 10.63.248.105: 1
administrator@GEUL3BNAGPAS01:/usr/local/nagios/libexec$ ./check_nrpe -n -H 10.63.248.105
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
npolovenko
Post
by npolovenko » Mon Nov 12, 2018 12:27 pm
@BrunoLosse1 , Are IP addresses NATed on your network? Please upload the most recent nsclient.log file from the windows server.
Privacy Policy .
BrunoLosse1
Post
by BrunoLosse1 » Tue Nov 13, 2018 6:16 am
npolovenko wrote: @BrunoLosse1 , Are IP addresses NATed on your network? Please upload the most recent nsclient.log file from the windows server.
No, we don't use NAT.
nsclient.log
Here's the log (1.56 MiB) Downloaded 264 times
npolovenko
Post
by npolovenko » Tue Nov 13, 2018 2:11 pm
@BrunoLosse1 , I can see a different kind of error in the log this time. Please change:
cache allowed hosts = 1
to
cache allowed hosts = 0
Then restart the nslcient and let me know if the problem goes away.
Privacy Policy .
npolovenko
Post
by npolovenko » Tue Nov 13, 2018 4:12 pm
@BrunoLosse1 , You don't need to use custom SSL serts, for now.
In the [/settings/NRPE/server] section of the ini file please add the following line:
ssl options =
And delete this line:
Then restart the NSClient service.
Run these commands from the Nagios server:
Privacy Policy .
