CHECK_NRPE: Receive header underflow - only 0 bytes received
raydx
Re: CHECK_NRPE: Receive header underflow - only 0 bytes rece
Post by raydx »
Attached shows output from requested commands. Thanks!
Nagios_issue.docx
(549.32 KiB) Downloaded 178 times
I asked you to change the path to the check_nrpe plugin if needed, if it is different on your system... How did you install NRPE? Do you know where is check_nrpe located on your system? Let's try to find it - run the following command and post the output:
find / -name *nrpe
One you locate check_nrpe, run:
/path/to/check_nrpe -H <windows server ip>
/path/to/check_nrpe -H <windows server ip> -p 5666 -c CheckMem -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
and show the output.
raydx
Post by raydx »
I did a sanity check and ran:
sudo apt-get install nagios-nrpe-plugin
The plug-in did install - no message about the plugin already installed.
However, I'm still getting check_nrpe: command not found after running /path/to/check_nrpe -H <windows server ip>
The plug-in is in /usr/local/nagios/libexec and /usr/lib/nagios/plugins/check_nrpe
You probably didn't have to install NRPE from a repo. Now you have check_nrpe in two different locations. You don't need two plugins...
Note: Your command didn't work because you didn't run it as I asked you to... I asked you to run:
/usr/local/nagios/libexec/check_nrpe -H <windows server ip>
You CD-ed to libexec directory instead and ran:
check_nrpe -H 10.11.96.194
That's why you got the "check_nrpe: command not found" message. Since you were already inside the libexec directory, you should've run:
./check_nrpe -H 10.11.96.194
Let's see which plugin works for you. Run the command below, and show the output:
/usr/local/nagios/libexec/check_nrpe -H 10.11.96.194
/usr/local/nagios/libexec/check_nrpe -H 10.11.96.194 -p 5666 -c CheckMem -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
/usr/lib/nagios/plugins/check_nrpe -H 10.11.96.194
/usr/lib/nagios/plugins/check_nrpe -H 10.11.96.194 -p 5666 -c CheckMem -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
raydx
Post by raydx »
Thank you for your assistance (and patience).
administrator@SVNagios02:/usr/local/nagios/libexec$ ./check_nrpe -H 10.11.96.194
I (0.5.2.35 2018-01-28) seem to be doing fine...
administrator@SVNagios02:/usr/local/nagios/libexec$ ./check_nrpe -H 10.11.96.194 -p 5666 -c CheckMem -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
OK: physical: Total: 7.99GB - Used: 1.037GB (12%) - Free: 6.953GB (87%)|'physical'=1.0372GB;6.39235;7.19139;0;7.99044 'physical %'=13%;80;90;0;100
The check_nrpe in libexec directory seems to be working fine, so let's try again the check that was failing:
cd /usr/local/nagios/libexec
./check_nrpe -H 10.11.96.194 -c check_eventlog -a "filter=provider = 'SLMD UV Monitor Loader' and id = 0 and message like 'Config socket blocked' OR message like 'Inconsistent state'"
Do you have a section in the nsclient.ini file, named [/settings/eventlog]? Can you show us what are the directives that are defined under this section? If the check above fails, please post the nsclient.log from the Windows server.
raydx
Post by raydx »
nsclient.log
(11.42 KiB) Downloaded 266 times
Running the check that failed:
administrator@SVNagios02:/usr/local/nagios/libexec$ ./check_nrpe -H 10.11.96.194 -c check_eventlog -a "filter=provider = 'SLMD UV onitor Loader' and id =0 and message like 'Config socket blocked' OR message like 'Inconsistent state'"
CHECK_NRPE STATE CRITICAL: Socket timeout after 10 seconds.
nsclient.ini has the following sections:
; NRPE server settings
[/settings/NRPE/server]
allow arguments = true
allow nasty characters = true
insecure = true
verify mode = none
; NRPE modules
[/modules]
NRPEServer = enabled
CheckExternalScripts = enabled
CheckHelpers = enabled
CheckNSCP = enabled
CheckEventLog = enabled
CheckDisk = enabled
CheckSystem = enabled
The nsclient.ini is identical to the one on the server where this check does function without issue.
nsclient.log is attached. Thanks.
To be sure, edit the nsclient.ini file and verify that the following options for the eventlog check are in the file and setup like the following.
; DEBUG - Log more information when filtering (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = 0
; BUFFER_SIZE - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
buffer size = 131072
; LOOKUP NAMES - Lookup the names of eventlog files
lookup names = 1
; SYNTAX - Set this to use a specific syntax string for all commands (that don't specify one).
syntax = UNKNOWN
Save and restart NSClient++
Another thing, the default timeout of the plugin is fairly short and if it takes some time to run the check, it could fail with the same message.
In the check_nrpe command, add a -t 59 to the command to increase it to 59 seconds.
./check_nrpe -H 10.11.96.194 -c check_eventlog -t 59 -a "filter=provider = 'SLMD UV onitor Loader' and id =0 and message like 'Config socket blocked' OR message like 'Inconsistent state'"
raydx
Post by raydx »
Ran the ./check_nrpe with -t 59 and returned:
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
In running with the up-date nsclient.ini file:
The server where this check is functional, its nsclient.ini file does not have the options for the eventlog check and setup.
Can you post the full nsclient.ini file here so we can view in in case there is another configuration setting that is causing the check to fail?
