After upgrade to latest version Received following message from Nagios:
Could not construct return packet in NRPE handler check client side (nsclient.log) logs...
At host end, nsclient++ logged the following:
error:modules\NRPEListener\NRPEListener.cpp:317: Exception handling NRPE packet: Invalid packet version.
Re: Could not construct return packet in NRPE handler
Newer versions of check_nrpe use version 3 by default and nsclient needs version 2. check_nrpe can be configured to use version 2 using the "-2" option. See https://support.nagios.com/forum/viewto ... on#p266038 fro steps.
Thanks!
I am not authorized to view this topic:
Kindly assist.
Kindly assist.
Sorry about that! This link was provided by mistake. It's from a customer support forum. There is not so much in the thread though - it was just mentioned that depending on the version of the NSClient++, v3 packets may or may not be supported. What is the version of the NSClient++ agent that you are currently using?I am not authorized to view this topic:
viewtopic.php?f=16&t=50874&p=266038&hilit=Exception+handling+NRPE+packet%3A+Invalid+packet+version#p266038
Have you tried adding the "-2" option to your check to see if this is going to solve your problem?
Example:
./check_nrpe -2 -H <ip address> -c <command> -a <arguments>Be sure to check out our Knowledgebase for helpful articles and solutions!
Hi @lmiltchev,
NSClient++ Version 2, June 1991
Kindly provide us the full command that we need to execute. Host IP address is 10.215.222.75
Also, is there anything else we need to try if this wouldn't work?
Thanks again!
Thanks again!
This is a VERY old version of NSClient++, which won't work with the NRPE v3. You will need to upgrade your NSClient++ agent.NSClient++ Version 2, June 1991
I wouldn't know what kind of command you would like to execute, in order to provide you with the "full command"...Kindly provide us the full command that we need to execute. Host IP address is 10.215.222.75
The correct syntax would be:
/usr/local/nagios/libexec/check_nrpe -2 -H 10.215.222.75 -c <command> -a <arguments>Note: Passing arguments is optional, depending on how the command is defined. Arguments could be "hard-coded".
Thank you for your suggestion!
We will upgrade to latest NSClient++ and after that try again
Cheers!
Cheers!
Let us know if you have any further questions. Thanks!
